Menu Option | Description | Toolbar Icon |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See Understanding Docked Panes and Standalone Window Tools on page 2-13 for more information on dockable and standalone windows. | -- |
Exit | Closes the SCADA Status window. | -- |
Display FEP Monitor... | Opens the FEP Monitor as a tab in the docked pane. See FEP Monitor on page 10-7 for information. | -- |
Display IED Monitor... | Opens the IED Monitor as a tab in the docked pane. See IED Monitor on page 10-16 for information. | -- |
Display Point Monitor... | Opens the Point Monitor as a tab in the docked pane. See Point Monitor on page 10-11 for information. | -- |
Display IED Templates | Opens a new IED Template as a tab in the docked pane. See FEP Details on page 10-13 for information. | -- |
Display Audit Log... | Opens a new IED Template as a tab in the docked pane. See SCADA Audit Log on page 10-42 for information. | -- |
Display Debug Log... | Opens a new IED Template as a tab in the docked pane. See SCADA Debug Log on page 10-42 for information. | -- |
Create New FEP | Opens the FEP Details tool allowing the user to create a new FEP. | |
Create New IED... | Opens the IED Details tool allowing the user to create a new IED. | |
Create New IED from Template... | Creates a new IED as copy of a preconfigured template and opens the IED Details on the resulting new IED. | |
Download IED Schema... | Allows you to download the schema xsd file that defines the schema used by NMS for validating against imported IED configuration. | |
Export IED... | Allows you to export selected IED configuration from tree view in XML format. The default file name is IEDNAME.xml. | |
Import IED... | Allows you to import an XML file containing valid IED configuration. | |
Unlink IED... | Immediately disassociates the currently selected IED from the FEP and moves it to the unassociated list. | -- |
Move IED... | Invokes the Associate IED dialog allowing the user to associate the currently selected IED to one of the configured FEPs. | -- |
SCADA Status Help | Opens online help content for the SCADA Status window | -- |
