Menu Option | Description | Toolbar Icon |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See Understanding Docked Panes and Standalone Window Tools on page 2-13 for more information on dockable and standalone windows. | -- |
Exit | Closes the FEP Monitor. | -- |
FEP Details... | Display the FEP details window for the selected FEP. | |
Display IEDs for FEP... | Display the IED Monitor list filtered for IEDs on the selected FEP. |
Enable FEP | Enables the selected FEP | |
Disable FEP | Disables the selected FEP | |
Reset FEP Statistics | Resets the communication statistics for the selected FEP. | |
Reset All IED Statistics | Resets the communication statistics for all IEDs configured on the selected FEP | |
Synchronize | Resynchronizes the FEP configuration to the FEP itself. | |
Add FEP... | Creates a new FEP. | |
Remove FEP... | Removes the selected FEP component. | |
Enable Connection | Enables the selected FEP connection. | |
Disable Connection | Disables the selected FEP connection. | |
Change Active Connection | Changes the communications channel used to communicate to the FEP. Only visible if the FEP has multiple channels configured. | |
Enable Debug | Enables the logging of debug messages for the selected FEP. | |
Disable Debug | Disables the logging of debug messages for the selected FEP. |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. See Using the Sort Dialog Box on page 1-9. | -- |
Default | Sorts the table using the standard sort criteria. | -- |
FEP Monitor Help | Opens online help content for the FEP Monitor. | -- |
