Menu Option | Description | Toolbar Icon |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See Understanding Docked Panes and Standalone Window Tools on page 2-13 for more information on dockable and standalone windows. | -- |
Exit | Closes the FEP Monitor tab. | -- |
View | Focuses the Viewer on the selected device. |
Remove Point | Removes the point from the Point Monitor. | -- |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. See Using the Sort Dialog Box on page 1-9. | -- |
Default | Applies the default sort. In the product configuration, the default sort is by Point ID. | -- |
Type | Applies the sort by input type. In the product configuration, this sort is by Point ID and Type. | |
IED Name | Applies the sort by IED. In the product configuration, this sort is by Point ID and IED Name. |
