Menu Option | Description | Toolbar Icon |
Disable FEP | Disables the selected FEP | |
Enable FEP | Enables the selected FEP | ![]() |
Add FEP | Creates a new FEP. | ![]() |
Remove FEP | Removes the selected FEP component. | ![]() |
Add Connection | Adds a new connection to the FEP. | |
Delete Connection | Deletes the current connection. | ![]() |
Enable Connection | Enables the selected FEP connection. | ![]() |
Disable Connection | Disables the selected FEP connection. | ![]() |
Change Active Connection | Changes the communications channel used to communicate to the FEP. Only visible if the FEP has multiple channels configured. | ![]() |
