Menu Option | Description | Toolbar Icon |
Display IEDs on all FEPs | Removes any filters on the IED Monitor list and displays all IED's | |
Create New IED | Opens the IED Details tool allowing the user to create a new IED. | |
Create New IED from Template | Creates a new IED as copy of a preconfigured template and opens the IED Details on the resulting new IED. | |
Create New Template from IED | Creates a new template IED as copy of an existing IED and opens the Template Details on the resulting new template. | |
Delete IED | Deletes the selected IED. | |
Enable IED | Enables the selected IED. | |
Disable IED | Disables the selected IED. | |
Force Poll IED | Initiates a read of all inputs on the selected IED. | |
Reset IED Statistics | Resets the communication statistics for the selected IED. | |
Enable Connection | Enables the selected IED connection. | |
Disable Connection | Disables the selected IED connection. | |
Change Active Connection | Changes the communications channel used to communicate to the IED. Only visible if the IED has multiple channels configured. | |
Reset Connection Statistics | Resets the communication statistics for the selected IED connection. |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. | -- |
Default | Applies the default sort. In the product configuration, the default sort is by IED Name, IED ID, and Connection ID. | -- |
