Actions Menu
Menu Option
Description
Toolbar Icon
Enable IED
Enables the selected IED.
Disable IED
Disables the selected IED.
Create New IED
Creates a new IED.
Create New IED From Template
Creates a new IED as a copy of a predefined template.
Add Template To IED
Creates new input and output points on the current IED as a copy of a predefined template.
Create New Template From IED
Creates a new template IED as a copy of the current IED.
Remove IED
Deletes the current IED.
Add Connection
Adds a new connection to the IED.
Delete Connection
Removes the selected connection from the IED.
Enable Connection
Enables the selected IED connection.
Disable Connection
Disables the selected IED connection.
Change Active Connection
Changes the communications channel used to communicate to the IED. Only visible if the IED has multiple channels configured.
Sort Menu
Menu Option
Description
Toolbar Icon
Input Sort
Input Sort defines sorts for the input points tab.
• Sort Dialog…: Invokes the sort dialog window to allow custom sorts of the input list.
• Default: Sort the input list by the default sort. The default sort is based on the protocol of the IED.
• DNP3: Sort on the Information Object Address
• IEC104: Sort on the address
• ICCP: Sort by Transfer Set
• Type: Sort by the type of the input (analog and digital).
• RTI Alias: Sort by the RTI Alias of the linked NMS device.
Output Sort
Output Sort defines sorts for the output points tab.
• Sort Dialog...: Invokes the sort dialog window to allow custom sorts of the output list.
• Default: Sort the output list by the default sort. The default sort is based on the protocol of the IED.
• Type: Sort by the type of the output (analog and digital).
