IED Default Scaling Options
The default scaling options are a definition of the analog scaling values that will be used for all analogs on an IED unless overridden by values on the input itself:
• Absolute Change: Default required absolute difference before being reporting
• Percent Change: Default required percentage difference before being reporting
• Offset Before Multiply: Default add value before multiply operation - use negative value for subtraction
• Offset After Multiply: Default add value after multiply operation - use negative value for subtraction
• Scale Multiplier: Default multiplier for analog values
