Using the Analog Scaling Dialog Box
The Analog Scaling dialog box allows you the analog scaling parameters of an input or set of inputs.
The dialog consists of three sections:
• Select Scaling option
• Scaling Details
• Buttons
Select Scaling Option
The Select Scaling option allows you to assign individual scaling parameters to a set of inputs or to default to the IED scaling options.
• IED Defaults: Selecting this option sets the scaling options for the points to the IED’s default values.
• Point Overrides: Selecting this option allows you to override the IED default scaling options for the selected points.
Scaling Details
The following scaling parameters are available to set:
• Absolute Change: The absolute deadband value
• Percentage Change: The percentage deadband value
• Multiplier: The scaling multiplier to apply.
• Offset Before Multiplier: The offset to apply to the value before any multiplier is applied. Negative values are subtracted.
• Offset After Multiplier: The offset to apply to the value after any multiplier is applied. Negative values are subtracted.
Each of the scaling parameters has two values:
• IED: The IED default value. This field is not editable.
• Point: The override value that will be used instead of the IED value. This field is only editable if the Point Overrides scaling option is enabled.
Buttons
• OK: Selecting OK closes the dialog and applies the scaling.
• Cancel: Selecting cancel closes the dialog and cancels the operation.
• Help: Selecting help invokes the online help.
IED Outputs
This display shows a protocol specific list of the output points on the IED. Context sensitive menu options allow creation, deletion and editing of output points.
