Export IED... Action
The Export IED... action allows you to export an IED configuration. Selecting this action opens a dialog box with four check box options:
• Header Information
• Protocol Specific Information
• Point Information
• Device Linkage Information
The exported information will be determined by your selection. The information is exported as an XML file.
Buttons
• Search: Allows you to select the location to save the xml file.
• Export: Completes the exports action and saves the XML file.
Note: The Export button is enabled when you select the location to save the XML file.
• Cancel: Cancels the export process and closes the dialog box.
