Menu Option | Description | Toolbar Icon |
Refresh | Refreshes the data in the Trend Graph window with the selected control zone's data. | |
Rescale | Reload the data for the currently visible time period. This option is not available in live trending mode. Note: trend lines for which there are no data points in the new time period will not be visible after rescaling. | -- |
Print... | Prints the trend graph for the selected region. | |
Pin | Click to pin the graph, which will open new graphs in separate windows. If a graph is not pinned, then when the Trend Graph option is selected again, the current window will display the data for the new selection. Note: You may pin multiple graphs. | |
Exit | Closes the Trend Graph window. | -- |
Graph Tool Help... | Opens the online help system to the Trend Graph help content. | -- |
