Menu and Toolbar Options
File Menu
Menu Option
Description
Toolbar Icon
Print...
Opens the Print dialog box, which allows to print the report.
Exit
Closes the Conductor Impedance Mismatch Tool window.
Actions Menu
Menu Option
Description
Toolbar Icon
Run Analysis...
Opens the Feeder Data Analysis dialog box, which allows you to input the analysis runtime in minutes.
Stop Analysis...
Stops the feeder data analysis if it has not already finished and displays the report in the table.
View...
Displays the selected conductor in the viewer.
Copy
Copies selected rows.
Purge Analysis Results...
Opens a confirmation dialog box that allows you to purge old analysis results.
Help Menu
Menu Option
Description
Toolbar Icon
Conductor Impedance Mismatch Analysis Tool Help
Opens the online help system to the Conductor Impedance Mismatch Tool help content.
