Menu Option | Description | Toolbar Icon |
View... | Focus the Viewer on the selected feeder. | |
Feeder Load Management Tool... | Opens and/or updates the Feeder Load Management Tool window. This button is disabled until you select rows in the Feeder Load Summary table with available FLM data. If multiple rows are selected, the Feeder Load Management window displays details for multiple feeders. | |
Show Errors and Statistics... | Displays the FLM Feeder Errors, Warnings, and Details dialog box that displays model warnings and errors for the selected feeder solution. See Feeder Errors and Warnings on page 17-10 and Using Power Flow Solution Details Window on page 12-20 for details.-- | -- |
Re-enable Island | The Re-enable Island action is enabled for Administration users when selecting a row with a Non-Convergent, Inconclusive, or Solution Failed. The action tells Power Flow services to attempt to solve the island for the next forecast. Note: This action is also available from the right-click context menu. | -- |
