Menu Option | Description | Toolbar Icon |
Exit | Closes the Feeder Load Management window. |
Real Time | Switches to real-time mode. (This option is desensitized if Real-Time Mode is active.) | |
Study Mode | Switches to study mode. (This option is desensitized if Study Mode is active.) | |
Study Session for Selected Row Profile | Launches a Power Flow Study Session in the viewer based on the conditions for selected row. The same forecast parameters for generation and loading will be utilized when setting up the load scenario in the Viewer. Users may utilize this option if a more detailed analysis needs to be conducted on the network for a future date and time. | |
Show Errors and Statistics... | Displays the FLM Feeder Errors, Warnings, and Details dialog box, which displays model warnings and errors for the selected feeder solution. See Feeder Errors and Warnings on page 17-10 and Using Power Flow Solution Details Window on page 12-20 for details. | |
Re-enable Island | The Re-enable Island action is enabled for Administration users when selecting a row with a Non‑Convergent, Inconclusive, or Solution Failed. The action tells Power Flow services to attempt to solve the island for the next forecast. Note: This action is also available from the right-click context menu. | -- |
Power Flow Options... | Allows you to configure Real-Time Power Flow Options if you are in real-time mode. If you are in Study Mode, click this button to configure Study Mode Load Scenario. | |
Select Columns... | Opens the Select Columns to Display dialog box for you to select which columns you want to appear in the table on the Feeder Load Management Feeder Load Overview tab. If a column is not checked, it will be displayed in the Additional Columns balloon details window rather than on the main window. | -- |
Feeder Load Management Help | Opens the online help system to the Feeder Load Management tool help content. | -- |
