Global ANMS Mode
The Global ANMS Mode controls the processing and execution of all schemes in the system. The mode can be in any one of the following states.
• Disabled: No processing of schemes will happen.
• Manual: Schemes will be processed. When scheme conditions are met by the system, an event will be created in the Work Agenda and an ANMS switching sheet will be created from the template. You will need to execute the sheet and complete the event.
• Automatic: Schemes will be processed. When scheme conditions are met by the system, an event will be created in the Work Agenda and an ANMS switching sheet will be created from the template. The steps in the sheet will be automatically executed.
Note: To set the ANMS Mode, select ANMS Mode from the Web Workspace Tools menu, and then select the desired mode (Disable, Manual, or Automatic). Only Administrators are allowed to change this mode.
