Saving Exported User Configuration
To generate and save SQL statements for the current state of the configuration associated with the User Administration tab, complete the following steps:
1. Click Export Configuration... beneath the Current Users table. A dialog box appears indicating that the configuration is being generated.
2. Once the generation is finished, the Generated Configuration dialog box appears.
• To save the generated SQL statements to a file, click Save. The Save Configuration File dialog box appears. Type a name for the file into the File name field. The Save Configuration File dialog box disappears.
• To print the generated SQL statements, click Print. The Print Preview dialog box appears.
• Click Cancel to close the Generated Configuration dialog box.
Understanding the User Type Memberships Pane
The User Type Memberships pane allows you to assign a selected user to Oracle Utilities Network Management System applications and set their permissions by user type (see also Understanding User Types on page 1-2) for each.
The User Type Membership pane displays the following fields and buttons:
• The Products column lists the Oracle Utilities Network Management System modules.
• The Remaining User Types column lists the user types available to be assigned to the selected product.
• The Current User Types column lists the user types assigned to the selected product.
