Using the Default Restoration Times Tab
The Default Restoration Times tab on the Configuration Assistant window displays the current default restoration time configuration and allows you to modify the ERT values for each device class by control zone.
Note: To change the system-wide default restoration time, see Setting the System-Wide Estimated Restoration Time on page 3-59.
Device/Zone Default Restoration Times Pane
The Device/Zone Default Restoration Times pane provides a tabular view that provides the relationship between a control zone, a device, and the default restoration time that has been set for them.
