Showing and Hiding Layers of Information
Tap to display the Hide/Display panel. Options here show and hide different layers of information.
Hide/Display
• Landbase: Toggle the visibility of the Landbase (if one is selected in the Settings panel)
• Offline Landbase: Toggle the visibility of the offline Landbase.
• Automatic Landbase: Automatically switch between landbases when the device goes offline/online.
• Secondary: Toggles the visibility of the Secondary network.
• Structures: Toggles the visibility of structures such as poles
• Non-Main Asset DA: Toggles the visibility of non-main asset damage report symbols.
• Customer Calls: Toggles the visibility of the Secondary network.
Annotations
• Conductor Current Phase Markers: Toggles the visibility of phase indicators on conductors.
• Device Labels: Toggles the visibility of device labels
• Device Nominal Phase Labels: Toggles the visibility of devices' nominal phase(s). If a device is in an abnormal state the background of the label is colored green (abnormally open) or red (abnormally closed).
• Conductor Nominal Phase Labels: Toggles the visibility of conductors' nominal phase(s). If a conductor is in an abnormal state the background of the label is colored green (abnormally de-energized) or red (abnormally energized).
• Conductor Feeder Labels: Toggles the visibility of conductor feeder labels.
• Flow Direction: Toggles the visibility of flow direction arrows.
Crew Types
• All
• Line
• Trouble
• Guide
• Service
• Eval
• Tree Crew
Conductor Highlight
• Assessed
• Predicted De-Energized
• Confirmed De-Energized
• Confirmed Degraded
