Options and Settings
Tap () to access Map Options and Settings
Tap the gear icon () to display the Settings panel. Options here enable you change visualization and behavior of the Map. Note that the Map updates as you adjust them:
• Landbase Source: Enables you to select different landbases, including an offline landbase.
• Landbase Opacity: Select the visual intensity of the landbase.
• Show Offline Landbase when Offline: Automatically switches to the downloaded offline landbase when you are offline. When you reconnect your selected online landbase will be automatically restored.
• Map Theme: The Map theme can be changed to support low-lit or well-lit working environments. The following options are available:
• Automatic (Follow Theme): Inherits the Light or Dark theme selected in the main OMA Setting dialog.
• Dark: Displays the dark Map theme regardless of the currently applied theme.
• Light: Displays the light Map theme regardless of the currently applied theme
• Symbol Scale: Select the preferred symbol size/scale (applies to devices and symbols)
• Big Symbols: When selected displays preconfigured symbols larger when zoomed out.
• Big Symbol Scale: Select the scale of big symbols, when they are displayed.
• Line Scale: Select the thickness of conductors.
• Text Scale: Select the size of text displayed in labels
• Condition Distance Scale: Select the distance at which conditions and outage symbols display from their associated device.
• Conductor Highlight Blur: Display conductor highlighting with sharp edges, or with blurred edges.
• Conductor Highlight Opacity: Select the intensity/opacity of the highlighting.
• Conductor Highlighting Scale: Select the thickness of conductor highlighting.
• Trace Outline Opacity: Select the intensity/opacity of traces.
• Trace Outline Scale: Select the thickness of traces.
• Feeder Highlight Opacity: Select the opacity/intensity of non-selected feeders, when Feeder Highlighting is applied.
• Conductor Dashing Mode: Conductor line styles can be applied to indicate phasing or overhead/underground
• Underground Cables: Display underground conductors with dashed lines.
• Phase Count Dashes: Display number of phases as dashes.
• None: Do not display underground cable dashing or phase count dashes.
• Rotate Device Symbols: Display device symbols in the same orientation or aligned with the network.
• Device Labels Always to the Right: When selected, displays device labels to the right of the device.
• Show Selection Panel when Item is Selected: When selected, displays the Selection panel for the device.
Note: When deselected the panel is not shown by default, but can be shown by tapping on the Map toolbar or by selecting the same option from the selected device's right click context menu.
• Do Not Move Map When Panels Open: When selected, as Map panels are displayed the Map does not move to accommodate the panel.
• Inertial Panning: When selected, the Map exhibits "momentum" after panning with the mouse or finger.
• Smoothly Animate Between Positions: When selected, the Map smoothly pans and zooms between different positions; for example when clicking Back or Forward, when targeting on nearby events, or displaying the extent of a trace.
• Auto-reset to Default Selection Mode: When selected, returns to the default Map selection mode. For example, after switching to Measure Distance mode or Geographic Location mode.
After changing settings in this panel, click OK to apply the changes, or click Defaults to restore the factory settings.
The changes you apply here will be saved on your device.
Map Refresh
• Automatic Refresh Enabled: Refreshes the Map with real-time device status, energization states, conditions and crews, etc.
• If Automatic Refresh is disabled, the following options are enabled:
• Current Information: Performs a manual refresh of the latest network updates from the NM server.
• Notes, Tags, Crew, Events etc.: Refreshes the Map with the latest conditions. This does not load new Maps or change the Map mode.
• Default Network Status: Refreshes the Map to display the nominal network state. If the map has some real-time statuses, this icon will be red indicating it will be reset to nominal if tapped.
• Map Updates: Checks for available Map updates and enables you to download them.
View
Options available here provide different views of the electrical network:
• Color by Feeder: When selected, colors the network feeder by feeder.
• Color by Phase: When selected, colors the network by phase.
• Color by Nominal Voltage: When selected, colors the network by nominal voltage.
• Color Secondary by Color Mode: When selected, displays the secondary network by the currently selected "Color by…" option.
• Color Secondary by State: When selected, displays the electrical state of the secondary network.
• Show Nominal Network State: When selected, displays the nominal state of devices and conductors.
• Declutter Symbols: When selected, declutters the network when zoomed out.
• Map Color Legend: Displays the Map Color Legend dialog, which illustrates the colors, highlights, and line styles for the different electrical states, phases, and voltages.
Selection Options
Options here provide different ways of accessing and selecting objects on the Map.
• Open / Close the Selection Panel: When selected, the Selection Panel will slide out each time an object is selected in the Map.
• Select Map Location: Enables you to tap on a location on the Map, and display its geographic co-ordinates.
• Single Touch Action: Select map objects with single touch action
• Circle Action: Select map objects with circle action
• Box Action: Select map object with box action
• Polygon Action: Select map object with polygon action
• polygon represented by connected points Measure Distance: You can measure distances on the Map
• Tap on the map to add a start position.
• Move to a different position and tap again to create a turning point. Repeat as necessary.
• Tap on the last point to complete the measurement. The distance is displayed in the top-right corner of the Map.
• Tap anywhere in the Map to remove the measurement.
• Clear Selection and Action: Clears the selected objects from the Selection List panel and the map.
GPS Location
Options here provide access to location and tracking information:
• Track Current Location: Tracks your current location on the Map
• GPS Location: Provides options to focus the Map on your desired location.
• Goto GPS Location: Focuses the Map on your GPS location.
• Select Map Location: Focuses the Map on a selected location.
• Directions to Location: Opens the device's native navigation app to assist you in driving to the task location.
• Diamond shape with arrow icon that launches a map application. Add Damage Report for Location: Allows you to create a damage report at the selected location.
Navigation
• Show Map Search: Displays the Map Search dialog
• Diamond shape with arrow icon that launches a map application. Find Assessments: Lists all of your active patrol assessment conditions. From the Assessment panel, you can select an assessment condition and the Map will focus on the condition.
• Back: Navigate back to the previously viewed Map position Forward: Navigate forward to a previously viewed Map position.
