Map Options
Enable Map Tracking Option
When selected, the Enable Map Tracking Option check box enables the Track Current Location function. (Track Current Location is available from the GPS Location menu and automatically keeps the Map centered on your position as you move)
Feeder Automation Indicators
When selected, these provide additional information to Crews about the DMS status of feeders. These indications are displayed on the Task Details cards and the Map Selection Panel, for the selected device
Other options may be made available to you based on project requirements.
About
The About page provides information about the application and associated servers.
Application Information
Product Version: The OMA release that is running.
Project Version: The version number for a build of OMA with project specific customizations.
Application Key
Application Server: Information about the NMS application server.
Mobile Server: Information about the NMS mobile gateway server.
Logout
To log out, select the main menu and the Logout button. On logout, you may be asked a number of questions, for example:
Would you like to suspend your active jobs?
Would you like to mark your crew as off-shift on logout?
