Understanding Table Components
The following image shows an illustrated screen capture of a table showing call outs for the components.
2. Disable filtering button (
) temporarily disables (removes) currently applied filters; clicking the button again restores the filters.
3. The applied filter name (for example, Default).
8. The header row check box allows you to select all of the table rows.
