Understanding the Events and Crews Page Controls
Icons in the Events pane and Crews pane title bars allow you to control the position and display of the panes.
Buttons available in the Events and Crews title bars allow you to control the position and display of the panes.
1. Relative Position (Button to change position of Crews pane to be to the right of the Events pane.;Events Panel Only): Click to arrange the Events and Crews panels side-by-side. The icon will update to a clockwise arrow (Button to restore the position of Crews pane to below the Events pane.) that, when clicked, will restore the top and bottom layout.
2. Minimize Pane (Button will minimize the pane.): Click to minimize the pane to its title bar, which will maximize the other pane. When a pane is minimized, you can display it temporarily by clicking the title bar. The button will change to a Restore button (Button to restore a minimized or maximized pane to its standard position.); click the Restore button to restore the pane to its previous layout.
3. Maximize Pane (Button will maximize the pane and minimize the other pane to its title bar.): Click to maximize the pane, which will minimize the other pane. Alternatively, you can double-click the title bar to maximize it. The button will change to a Restore button (Button to restore a minimized or maximized pane to its standard position.); click the Restore button to restore the pane to its previous layout.
4. Close Events and Crews Tab (Button to close the Events and Crews tab.): Click to close the pane.
Note: These pane controls are also available when viewing a safety document associated with a switching sheet.
