Working with Attachments
The Event Details Attachments tab allows you to work with files that are relevant to the event.
Adding Event Details Attachments
1. To add an attachment, select the Event Details Attachments tab.
2. Click the
Add Attachment button (
) on the toolbar (or you may select the option from the
Actions menu).
3. Drag and drop a file to the Attachment dialog box.
4. You may, optionally, add a URL and/or description of the file.
Editing Event Details Attachments
1. To edit an attachment, select the attachment row in the Attachments tab.
2. Right-click and select
Edit Attachment.
3. In the Attachment dialog box, you can change the data in any of the fields and/or replace the file with a new version, as necessary.
Removing Event Details Attachments
1. To remove an attachment, select the attachment row in the Attachments tab.
Remove Attachment. The attachment will be deleted and the attachment row removed from the Attachments table.
Downloading Event Details Attachments
1. To download an attachment, select the attachment row in the Attachments tab.
2. Right-click and click
Download Attachment; alternatively, you may double-click the row and the file will download. The file will be saved to your browser's default download folder.
Working with Events in Flex Operations
