Creating a New Event
You can create a new event on a device or conductor.
1. In the Map, select a device or conductor
2. From the Selection Panel’s Event menu, select Create Event (Create Event toolbox with asterisk symbol.) to display the Create Event for Device dialog box.
3. Enter the information, then click OK.
For more information on creating events, see Creating an Event on page 2-29.
Managing Crews in Flex Operations
Flex Operations allows you to:
• Assign crews to outage events.
• Record crew status updates.
• Add, edit, and delete crews.
