File Menu
The File menu allows you to print the map view or close the map tab/window.
Print
The Print option allows you to print the Map with what devices and conditions are currently visible (using the current Hide/Display options).
Select Print from the Map's File menu. The map area will be displayed in preview mode. You can pan and zoom in the Print Preview view to change the area of the map to print.
Click the Print Selected Region button (Printer icon) to view the Print view where you can select a printer to print to or save as a PDF.
To cancel without printing, click the Cancel Print button (Print cancel icon.).
Exit: Closes the Map window
