Get Directions or Access Other Map Views
The
Navigate menu allows you to select from options based on the object selected.
• Directions to Location opens a navigation site (in a new browser tab) to get directions to the object's location.
Cycle Available Geographic and Internal Map Views cycles through different views of the device (schematics, geographic, and so forth).
View Full Extent zooms out to show the device in relation to its network.
View in Geographic Map changes the Map to the geographic view.
View Schematic Map changes the Map to the schematic view.
View Single-Feeder Map changes the Map to show the feeder one line view.
Note: When using Flex Operations on a touchscreen, tap on a device to display a popup menu which enables you to:
• Display the selection panel
• View the device’s tooltip
• Display the device’s right-click menu
