Working with Tags
You can annotate add, edit, and remove device tags on the Map.
For more information about tagging devices, see
Tagging Devices on page 2-110.
To add a tag:
1. In the Map, click to select a device or conductor, then from the
Selection Panel select
Add Tag from the
Tag/Note menu.
2. Choose the tag type, if prompted, enter tag text, if applicable, and then click Instruct or Complete. The tag is added.
Editing a Tag
1. In the Map, select the tag symbol, then from the
Selection Panel Tag panel, select
Edit Condition from the
Tag/Note menu.
2. Edit the text, then click OK.
Removing a Tag
In the Map, click to select the tag symbol, then from the
Remove Condition from the
Tag/Note menu.
