Using the Distance Measurement Tool
You can measure distances on the Map:
1. In the Map toolbar, click the measurement tool ().
2. Click in the map to add a start position.
3. Move to a different position and click again to create a turning point.
4. Double-click or click on the last point to complete the measurement. The distance is displayed in the top-right corner of the Map.
5. Click anywhere in the Map to remove the measurement.
Using the Geographic Location Tool
Feeder Highlights
You can highlight an entire feeder by hiding/subduing the other feeders.
For a selected device or conductor, click Feeder Highlights () then click Highlight Feeder. Other feeders will be displayed less prominently, but still be selectable (so you can highlight additional feeders).
To remove or clear feeder highlighting, click to select the feeder then choose Unhighlight or Clear Highlighting. You can also clear highlighting from the Highlighting indicator displayed in the top-right of the Map.
Viewing Downstream/Connected Customers
Click the Customer List... button to view a list of customers downstream of the selected device.
Examining Network Devices, Assets, and Symbols
To find out more about an asset or symbol, select it and then click the Attributes button from the Selection Panel.
