Examining Network Devices, Assets, and Symbols
To find out more about an asset or symbol, select it and then click the Attributes button from the Selection Panel.
Using the Trace Feature
The Trace tab enables you to perform traces:
1. Click to select a network asset like a device or conductor.
2. In the Trace To box, select the trace stop class.
3. Choose the Direction to trace.
4. Choose the Phase(s) to trace.
5. Click to perform the trace.
After a trace has been performed you can perform the following actions:
• Clear () the trace as displayed on the Map
• Refresh () the trace
• Target () the trace, to the Extent of the trace, or on the Start Point
• View ()the Trace Results. Trace results are displayed in a panel, and for each result you can right-click to position on the object, or fetch calculated values.
A list of recent traces is displayed, and actions can be performed on each trace in the list. See Executing Traces on page 2-84 for more information on trace options.
