Damage Assessment Procedures
Creating and Editing Damage Assessments
1. In the Event Details, select the Damage Assessment tab.
2. Select New Damage Assessment. The new Damage Assessment will open in a new tab.
3. Edit the details:
• In the upper panel, edit crew and reported date information.
• In the Damaged Assets tab, add a new damaged asset, or select a damaged asset from the list and edit it. (You can also delete a damaged asset item.)
• In the Damage Specifics tab, edit the number of crews, and other related information.
• In the Attachments tab, you can add, edit, or delete attachments.
• Add an Attachment
• Click the Add Attachment button () on the toolbar.
• Drag and drop a file to the Attachment dialog box.
• You may, optionally, add a URL and/or description of the file.
• Edit an Attachment
• Select the attachment row, right-click and select Edit Attachment.
• In the Attachment dialog box, you can change the data in any of the fields and/or replace the file with a new version, as necessary.
• Delete an Attachment
• Select the attachment row, click the Delete selected attachment button in the first column.
Progress the State of a Damage Assessment
The state of a damage assessment is displayed in the State field in the top panel. This can be progressed by the mobile-enabled user, or you can progress the state by selecting one of the following options from the Actions menu:
• Assessing
• Assessed
• Standing By
• Fixed
• Obsolete
For more information about Damage Assessments, see Working with Damage Assessments on page 3-48.
