Software Configuration
Configuration for the Oracle Utilities Network Management System ‑ Oracle Field Service Adapter comes from the following sources:
• CES_PARAMETERS database table
• Oracle Utilities Network Management System configuration rules
• Data mapping configuration
Support for Encrypted Configuration Parameters
Some configuration parameters that are stored in the CES_PARAMETERS database table contain sensitive information, such as authentication credentials, which should be protected. To protect this data, the VALUES column can be encrypted using Oracle WebLogic Server encrypt utility. This utility encrypts cleartext strings for use with Oracle WebLogic Server. Its output can then be used to populate values in CES_PARAMETERS database table.
Note: For detailed information see "encrypt" in the Oracle WebLogic Server Command Reference.
Entries in the CES_PARAMETERS database table for the Oracle Utilities Network Management System ‑ Oracle Field Service Adapter should have value 'MWMInterface' in the APP column. Column ATTRIB should contain name of the configuration parameter and column VALUE its value.
General Configuration Parameters
Parameter
Description
config.enabled
Enable/disable NMS-OFS interface.
Default: true
config.credentials
Absolute path to the file containing user credentials the adapter will use to communicate with Oracle Utilities Network Management System.
Either this parameter or both config.username and config.password parameters should be provided. If all are present, then the config.username/config.password pair is used.
config.username
Valid NMS username, which has the 'NmsService' role in WebLogic Server.
config.password
NMS user password. Value of this parameter should be encrypted.
config.nms_url
URL for accessing Oracle Utilities Network Management System. If this parameter is not provided then it is assumed that the adapter is deployed on the same WebLogic server as cesejb.ear.
mwm.use_rest
Use REST API for sending messages to the Oracle Field Service system.
This parameter must be enabled, which is the default setting.
config.activity_accepted_action
Key of the state transition action, which is executed when activity create/update message is accepted by the Oracle Field Service system.
config.activity_rejected_action
Key of the state transition action, which is executed when activity create/update message is rejected by the Oracle Field Service system.
config.default_crew_type
Default crew type.
The adapter uses this crew type when it needs to create a mobile crew which does not exist in NMS. This parameter should be set to the name of a valid NMS crew type. If not specified then the adapter will not be able to create crews.
config.allow_device_ops
Allow the adapter to operate device in NMS model.
Default: false
config.call_send_limit
Maximum number of customer calls (incidents) to be included into an activity create/update message sent by the adapter. Customer calls with higher priority are included ahead of the calls with lower priority.
Note: Including large number of calls greatly increases message size.
Default: 0
mwm.activity_id_prefix
Activity id prefix.
Default: NMS-
mwm.ws_request_timeout
Timeout (in seconds) for the outgoing web service requests. Requests would fail if response is not received before the timeout expires.
Default: 30
mwm.ack_wait_timeout
Timeout (in seconds) when waiting for acknowledgment of outgoing messages sent asynchronously. Link failure is declared if acknowledgment is not received before the timeout expires.
Default 60
mwm.url
Default URL of the web service where the adapter should send outgoing messages.
mwm.url.<operation name>
Operation-specific web service URLs. Allows for the outgoing messages to be send to the different URLs based on the message type (operation).
Valid operation names:
• PingURL - hearbeat message
• CreateUpdateOrder - creating or updating mobile activity
• CompleteOrder - completing or canceling mobile activity
• Notification - notification message
mwm.username
Username included in the outgoing messages as part of HTTP Basic authentication.
mwm.password
Password included in the outgoing messages as part of HTTP Basic authentication. Value of this parameter should be encrypted.
mwm.failure_limit
If the connection to OFS fails the number of times specified by this parameter within the time window specified by the 'mwm.failure_limit_window' parameter then NMS-OFS adapter will be stopped.
Setting the parameter to zero will disable the failure limit functionality.
After the adapter is stopped it needs to be restarted manually.
Default: 3
If the connection to OFS fails the number of times specified by the 'mwm.failure_limit' parameter within the time window (in seconds) specified by this parameter then NMS-OFS adapter will be stopped.
Default: 3600 seconds
Description Text for the Alarm Messages Generated by the Adapter
Parameter
Description
msg.started
The adapter has been started.
msg.stopped
The adapter has been stopped.
msg.established
Connection to the Oracle Field Service system has been established.
msg.synchronized
Synchronization sequence has finished.
msg.failed
Connection to the Oracle Field Service system has failed.
msg.too_many_failures
The adapter will be stopped due to failure limit.
msg.activity_rejected
Oracle Field Service returned error in response to a request to create an activity.
Note: this alarm is not current being generated.
msg.event_canceled
Event cancellation has been requested from the Oracle Field Service system but the event cannot be canceled in NMS.
msg.outage_restored
Outage restoration has been reported from the Oracle Field Service system but the outage cannot be restored in NMS (most likely because outage device cannot be closed).
msg.outage_confirmed
Outage has been confirmed by the Oracle Field Service system but the outage cannot be confirmed in NMS (outage device cannot be opened).
Query Configuration
Parameter
Description
query.type.<query type>
Query type.
Valid query types:
• device_info - device information
• customer - customer information
• call - customer call information for an event
query.<query type>.table
Database table or view to query.
Not applicable to the "device_info" query type.
query.<query type>.where
Additional conditions to be included in the query's WHERE clause.
query.<query type>.order_by
Query's ORDER BY clause (sorting condition).
query.<query type>.max_results
Maximum number of rows allowed to be returned for this query type.
Default: 100
query.<query type>.param.<param_name>
Maps query parameter name to a database column name.
The following parameters are defined for different query types:
• device_info
• deviceAlias - device alias
• customer
• accountNumber -customer account number
• call
• eventIdx - NMS event index
query.<query type>.column.<column_name>
Label for the data retrieved for the specified database column.
OAuth Configuration
General
Parameter
Description
config.auth.timeout
OAuth communication timeout (seconds).
Default: 30 seconds
Outgoing Requests
Parameter
Description
config.auth.token.url
URL for requesting OAuth token to be used for outgoing requests.
If this parameter is not specified then basic HTTP authentication will be used in outgoing requests.
config.auth.token.scope
The scope value used when requesting OAuth token to be used for outgoing requests.
config.auth.token.user
Username for requesting OAuth token to be used for outgoing requests.
config.auth.token.pwd
Password for requesting OAuth token to be used for outgoing requests.
This parameter should be encrypted in production environments.
Incoming Requests
Parameter
Description
config.auth.jwk
Either URL for requesting token signing certificate from OAuth server or the certificate itself.
If this parameter is not specified, then incoming requests with bearer token authentication will be rejected with error 401 (Unauthorized).
In production environments it is recommended to configure certificate itself instead of URL.
config.auth.allow.scope
The scope value used for validating OAuth tokens in incoming requests.
It should match one of the scope values in the received token.
config.auth.allow.user
The username used for validating OAuth tokens in incoming requests. It should match the principal or (if principal not provided) the subject in the received token.
Oracle Utilities Network Management System Configuration Rules
Oracle Utilities Network Management System configuration rules control various aspects of the system. You can configure these rules using the Oracle Utilities Network Management System Configuration Assistant tool. This section only covers the rules which directly affect the integration between Oracle Utilities Network Management System and Oracle Field Service system.
Rule
Description
crewFollowOutageDevice
This rule indicates whether or not crews dispatched to an event are automatically relocated if the device location changes. If this rule is enabled, dispatched crews are automatically relocated to the new device when an event moves to a different device in Oracle Utilities Network Management System. Typically, this rule should be enabled when Oracle Utilities Network Management System is integrated with Oracle Field SErvice system.
Default: no (disabled)
mobilePreassignCrew
Allows Oracle Utilities Network Management System user to assign and release mobile crews.
repredictionCrewReassignment
This rule enables or disables automatic crew reassignment/redispatch when event reprediction occurs in Oracle Utilities Network Management System.
For example:
Events A, B, and C exist on laterals off of a feeder backbone. Crew 1 is dispatched to event A, crew 2 is dispatched to event B, and crew 3 is assigned to event C. More calls come in on the feeder, eventually causing the system to repredict and group events A, B, and C to an upstream device. The resulting grouped event is called event A.
• If this rule is enabled, crew 1 remains dispatched to event A, crew 2 is undispatched from event B and redispatched to event A, and crew 3 is unassigned from event C and reassigned to event A.
• If this rule is disabled, crew 1 remains dispatched to event A, crew 2 is only undispatched from event B, and crew 3 is only unassigned from event C.
Default: yes (enabled)
sendToMobileState
This rule specifies the state(s) at which an event is sent to Oracle Field Service. When an event transitions to one of the states defined in this rule, a "send to mobile" flag is set in the event. The Oracle Utilities Network Management System-Oracle Field Service Adapter uses this flag to determine whether an event should be processed by the interface, triggering field order creation in Oracle Field Service.
Default: none
singleCrewPerEvent
This rule indicates whether or not multiple crews can be assigned or dispatched to an event in Oracle Utilities Network Management System. If this rule is enabled, only one crew can be assigned or dispatched to an event at any given time. The repreditionCrewReassignment rule is implicitly disabled if this rule is enabled.
useGenericAssign
Allows treating of crews with crew key less 1000 as "generic crews".
useMdt
This rule enables or disables MDT (Mobile Dispatch Terminal) crew flag functionality. This rule should be enabled when the Oracle Utilities Network Management System-Oracle Field Service Adapter is being used.
Data Mapping
Data mapping converts data elements between a data source and a destination. Oracle Utilities Network Management System ‑ Oracle Field Service Adapter uses data mapping configuration to determine activity type and notification type for the outgoing messages.
Data Mapping Overview
The Oracle Utilities Network Management System - Oracle Field Service Adapter provides a configurable data-mapping facility. This facility can be used to populate certain data elements in the outgoing messages.
Many-to-many data mapping: Most data flows from Oracle Utilities Network Management System to Oracle Field Service use many-to-many data mapping. This means that a source value can be mapped to many different target values, based on one or more conditions.
Data mapping is rules-based. Rule configuration is defined in the following database tables:
Mapping Table
Description
OMS_MWM_MAPPING_RULES
This table defines the field to be mapped and, for many-to-many mapping, the value to be written to the mapped field if all conditions are met.
OMS_MWM_MAPPING_CHECKS
This table defines conditions that may be applied to mapping rules.
OMS_MWM_MAPPING_RULE_CHECKS
This table associates a rule with a condition. Together, this table and the two previous tables are used to define many-to-many data mapping.
OMS_MWM_MAPPING_RULES Table
The OMS_MWM_MAPPING_RULES table contains rules for mapping data values between Oracle Utilities Network Management System and Oracle Field Service. The fields comprising each rule are described below:
Field
Description
rule_id
A unique identifier for this rule.
mapping
The name of the mapping rule set used to group related mapping rules. For example, the mapping rule set 'mwmOrder' defines rules for mapping Oracle Utilities Network Management System event data to the corresponding field order data in Oracle Field Service for outgoing orders.
mapped_field
The name of the field where the target value (the result of the mapping) should be written. For example, orderType, priority and alarmType are mapped fields.
mapped_value
This is the value to be written to the mapped field if all conditions defined for this rule are met. This is also referred to as the target value.
table_id
This field is not used.
rule_order
The order in which this rule should be applied when a series of rules is being used. The lowest value is used first.
Note: To define the default value for a field, configure a rule with no conditions and set that rule to be the last rule applied.
OMS_MWM_MAPPING_CHECKS Table
The OMS_MWM_MAPPING_CHECKS table contains conditions that can be used by the mapping rules defined in the OMS_MWM_MAPPING_RULES table.
Field
Description
check_id
A unique identifier for this condition.
field_name
The name of the field to which the condition applies.
cond_str
The condition to be applied. For a description of the condition format, see the next section.
negate
Indicates whether or not to negate the condition result. If this is set to Y, the result is negated. This field is optional.
Condition Format
Three different types of conditions are allowed in mapping rule checks. The format for each type of condition is shown in the table below.
Condition Type
Condition Format
Description
Exact string compare
<string to compare against>
The condition is true if the field value (converted to a string) exactly matches the comparison string.
Regular expression
@regex <regular expression>
The condition is the true if the field value (converted to a string) matches the given regular expression.
Class inheritance
@inheritFrom <class name>
The condition is true if the field contains the class name specified in the condition or the name of any child class.
Note: The angle brackets (<>) shown in the following table are not part of the format. The text inside the brackets should be replaced with the actual value as indicated.
OMS_MWM_MAPPING_RULE_CHECKS Table
This table is used to create many-to-many relationship between OMS_MWM_MAPPING_RULES and OMS_MWM_MAPPING_CHECKS tables. Each rule check associates a mapping rule with a condition (mapping check).
Field
Description
rule_id
The key to the mapping rule in the OMS_MWM_MAPPING_RULES table.
check_id
The key to the condition in the table OMS_MWM_MAPPING_CHECK table.
Mapping from Oracle Utilities Network Management System to Oracle Field Service
All data mapping rules for Oracle Utilities Network Management System to Oracle Field Service data flows belong to the "mwmOrder" rule set. This rule set supports mapping for the following data elements:
• Activity Type ( "orderType")
• Activity Priority ("externalPriority")
• Notification Type ("alarmType")
These data elements are mapped using many-to-many data mapping, as described in the following example.
Field Order Type Mapping Configuration Example
This example shows how to define data mapping rules to set the Oracle Field Service activity type to 'ROUTXFMWD' for events meeting the following conditions:
• The event is an RDO (real device outage);
• The event is on a transformer;
• The event has "Wire Down Pole-to-Pole" trouble code;
• The event is created under normal (non storm) conditions.
To configure data mapping for this example, complete the following steps:
1. Configure a mapping rule in the OMS_MWM_MAPPING_RULES table to set the Order Type to ROUTXFMWD. The rule set is 'mwmOrder'; the mapped field is 'orderType'; the mapped_value is 'ROUTXFMWD':
INSERT INTO oms_mwm_mapping_rules
(rule_id, mapping, mapped_field, mapped_value, rule_order)
VALUES (15, 'mwmOrder', 'orderType', 'ROUTXFMWD', 70);
2. Configure the required conditions in the OMS_MWM_MAPPING_CHECKS table:
/* RDO */
INSERT INTO oms_mwm_mapping_checks (check_id, field_name, cond_str)
VALUES (1, 'cond_status', '4');
/* Wire Down Pole to Pole */
VALUES (15, 'trouble_code', '@regex ^(.*[-,]|)P2P([-,].*|)$');
/* Non storm */
INSERT INTO oms_mwm_mapping_checks (check_id, field_name, cond_str, negate)
VALUES (33, 'rule_set', '@regex storm', 'Y');
/* Transformar */
VALUES (35, 'dev_cls_name', '@inheritFrom transformer');
Assign each of the four conditions (rules checks) to the mapping rule in the OMS_MWM_MAPPING_RULE_CHECKS table:
/* ROUTXFMWD */
INSERT INTO oms_mwm_mapping_rule_checks (rule_id, check_id)
VALUES (15, 1);
VALUES (15, 35);
VALUES (15, 15);
VALUES (15, 33);
Use the same process described above to configure data mapping for notification types (alarmType) and activity priority values (priority).
