Switching and Safety Web Service
There are two versions of this web service. One uses rpc-literal style and the other uses document-literal style. Both versions provide the same set of operations.
Port SwmanServiceBeanPort
Location: https://<nms host>:<nms port>/ExternalSwmanServiceImpl/SwmanServiceBean
Protocol: SOAP
Encoding style: rpc
Transport protocol: SOAP over HTTP
Target Namespace: http://www.oracle.com/ugbu/nms
Port SwmanServiceDocBeanPort
Location: https://<nms host>:<nms port>/ExternalDocSwmanServiceImpl/SwmanServiceDocBean
Protocol: SOAP
Encoding style: document
Operations
GetSafetyDocument
Retrieves safety document by handle.
Operation Type: Request-response. The endpoint receives a message, and sends a correlated message.
Input: GetSafetyDocument (soap:body, use = literal)
docHdl type handle
Safety document handle.
Output: GetSafetyDocumentResponse (soap:body, use = literal)
safetyDoc type SafetyDoc
Safety document
id - nillable; type long
Safety document identifier
externalId - optional; type normalizedString
Safety document external identifier
handle - nillable; type handle
docType - nillable; type normalizedString
Safety document type
state - optional; type State
Real-time state
swSheet - optional; type handle
Switching sheet handle
deleted - optional; type boolean
Safety document deleted flag
version - optional; type long
Safety document version (used for optimistic locking)
extensions - optional; type ArrayOfExtensionField
Extension fields
steps - optional; type ArrayOfSwStep
Switching steps associated with this safety document
step - optional, unbounded; type SwStep
Switching step
cls - nillable; type long
Switching step class
Switching step identifier
parentId - optional; type long
Parent step
groupNumber - optional; type long
Group number
device - optional; type handle
Handle of the main device associated with this switching step
deviceAlias - optional; type normalizedString
Alias of the main device associated with this switching step
controlZone - optional; type ControlZone
Switching step control zone
phases - optional; type phaseCode
Phases of the main device affected by this switching step
availablePhases - optional; type phaseCode
All phases of the main device associated with this switching step
secondaryDevice - optional; type handle
Handle of the secondary device associated with this switching step
groundNode - optional; type handle
Grounding node associated with this switching step
condition - optional; type handle
Condition associated with this switching step
Switching step real-time state
controlAction - optional; type ControlAction
Control Tool action
action - nillable; type normalizedString
switchingCode - optional; type normalizedString
attribute - optional; type long
[a] cls - required; type normalizedString
[a] idx - required; type normalizedString
[a] key - required; type long
Switching step control action
revision - optional; type long
Switching step revision number
description - optional; type string
Description
comments - optional; type string
Comments
plannedOffset - optional; type duration
Planned offset
createTime - optional; type dateTime
Date/time when this step was created
createUser - optional; type normalizedString
User who created this step
updateTime - optional; type dateTime
Date/time when step was last updated
updateUser - optional; type normalizedString
User who made the latest update this step
instructTime - optional; type dateTime
Date/time when step was instructed
instructUser - optional; type normalizedString
User who instructed this step
executeTime - optional; type dateTime
Date/time when step was executed
executeUser - optional; type normalizedString
User who executed this step
executeOrder - optional; type long
Step execution order
operationOutcome - optional; type normalizedString
Operation outcome
undoOperationOutcome - optional; type normalizedString
Undo operation outcome
resultOfOperation - optional; type normalizedString
Result of operation
resultFeeders - optional; type normalizedString
Result feeders
lastResultOfOperation - optional; type normalizedString
Last result of operation
editedOperation - optional; type normalizedString
Edited operation
modelBuild - optional; type normalizedString
Step affected by model build
safetyDocId - optional; type long
Safety document id (for safety-related steps)
safetyDevStatus - optional; type normalizedString
Status of the device as it pertains to the associated safety document. This is used to keep track of a user's modifications to a safety document's device list. ADD - The device has been added as part of a viewer device selection. ADD_STEP - The device has been added as part of a switching sheet step association. COND_APPLIED - The condition has been applied and updated to the device in the device list. INCOMPLETE - The device is associated to a switching step where the condition has already been applied to the device. REMOVE - The device has been marked for removal and will be removed the next time the document transitions from the Unissued to Issued state. REMOVED - The device has been removed from the device list. These devices are filtered out of the device list.
safetyCondAdded - optional; type long
Safety document version number where this safety condition step was added
safetyCondRemoved - optional; type long
crews - optional; type ArrayOfCrewId
Crew ids
Extension fields
crews - optional; type ArrayOfSafetyCrew
Crew information associated with this safety document
crew - optional, unbounded; type SafetyCrew
Crew information associated with a safety document
crewId - optional; type normalizedString
Crew id
position - optional; type normalizedString
Position the crew is in with regards to the zone of protection
auditLog - optional; type ArrayOfAuditLogEntry
Audit log entries
log - optional, unbounded; type AuditLogEntry
Audit log entry
Audit log entry identifier
entryType - optional; type normalizedString
Audit log entry type
userLog - optional; type string
User log
Device handle
Device alias
State
Revision number
comment - optional; type string
Log comment
Phases
Crew ids
Fault: OmsServiceException (soap:fault, use = literal)
fault type OmsServiceException
GetSafetyDocumentsForSheet
Retrieves all safety documents for a switching sheet.
Input: GetSafetyDocumentsForSheet (soap:body, use = literal)
sheetHdl type handle
Switching sheet handle.
Output: GetSafetyDocumentsForSheetResponse (soap:body, use = literal)
safetyDocs type ArrayOfSafetyDoc
List of safety documents
safetyDoc - optional, unbounded; type SafetyDoc
Safety document (see GetSafetyDocument)
GetSwitchingSheet
Retrieves switching sheet by handle.
Input: GetSwitchingSheet (soap:body, use = literal)
Output: GetSwitchingSheetResponse (soap:body, use = literal)
swSheet type SwSheet
Switching sheet
Switching sheet identifier
Switching sheet external identifier
Handle of the main device associated with this switching sheet
Alias of the main device associated with this switching sheet
Switching sheet control zone
owner - optional; type normalizedString
Switching sheet owner
Switching sheet revision number
version - nillable; type long
Switching sheet version (used for optimistic locking)
checkedIn - optional; type normalizedString
Switching sheet is checked in
Real-time state
Date/time when this sheet was created
User who created this sheet
Date/time when this sheet was last updated
User who updated this sheet last
lockedTime - optional; type dateTime
Date/time when sheet was locked
lockedUser - optional; type normalizedString
User who locked this sheet
startTime - optional; type dateTime
Date/time when execution of this switching sheet is expected to start
finishTime - optional; type dateTime
Date/time when execution of this switching sheet is expected to finish
completedTime - optional; type dateTime
Completion date/time
reworkDescription - optional; type string
Rework description
reworkTime - optional; type dateTime
Rework date/time
defaultOffset - optional; type duration
Default offset
Switching sheet is affected by model build
Extension fields
Switching steps
Switching step
Parent step
Group number
Control tool action
Description
Comments
Planned offset
Operation outcome
Result of operation
Result feeders
Edited operation
Crew ids
Extension fields
Audit log entries
Audit log entry
User log
Device handle
Device alias
State
Revision number
Log comment
Phases
Crew ids
standaloneSafetyDoc - optional; type SafetyDoc
createSwmanSheetFromExternalSystem
Creates new or updates an existing switching sheet.
Input: createSwmanSheetFromExternalSystem (soap:body, use = literal)
dataString type string
XML representation of the switching sheet.
Output: createSwmanSheetFromExternalSystemResponse (soap:body, use = literal)
return type int
Return code.
sheetStateTransition
Executes state transition on a switching sheet.
Input: sheetStateTransition (soap:body, use = literal)
actionType type string
State transition action type.
actionName type string
State transition action name.
username type string
Username.
Output: sheetStateTransitionResponse (soap:body, use = literal)
