Related Runtime and Configuration Tables
The following runtime and configuration tables are related to the weather adapter.
PF_WEATHER_ZONE: Configures the weather zones for use by the DMS analysis. The latitude and longitude can be specified for each zone within this table.
PF_WEATHER_ZONE_FORECAST: Stores the weather zone forecast. The temperature forecast is placed within this table by the adapter.
PF_DERMS_FORECAST_HISTORY: Stores the weather zone history. The temperature data is archived in this table for use by the NMS Profile Adapter.
CES_PARAMETERS: Stores the configuration parameters proxy.https and sourceDBServer where app=WeatherAdapter.
PF_WEATHER_DATA_PROFILE_MAP: Stores the mapping between the weather data and profile keys for the specified power sources.
