Parameter | Description |
nms.instance | NMS instance identifier. If data from multiple NMS instances is loaded into a single instance of Storm ERT application, then each NMS instance should have unique identifier. |
extract.dir | Folder where to store generated files. |
cz.hierarchy_type | NMS control zone hierarchy type. NMS supports multiple control zone hierarchies. This parameter defines which hierarchy to use when extracting data. Default: 1 |
db.host | Entry from NMS database wallet used to connect to the source database. If empty, then the value of the RDBMS_HOST environment variable is used. |
compress.level | Data compression level (1 through 9). If specified extract files will be compressed using gzip. |
oci.bucket | Object storage bucket name. |
oci.namespace | Object storage namespace. |
sftp.server | SFTP server hostname or IP address. |
sftp.port | SFTP server port Default: 22 |
sftp.user | SFTP username. |
sftp.identity | SSH identity or private key file. |
sftp.path | Upload directory on the SFTP server. |
gpg.key | GPG encryption key id. |
openssl.key | Full path to the OpenSSL encryption key. |
openssl.cipher | OpenSSL cipher to use. Default: aes256 |
rpt_level_1 | Label for reporting level 1. |
rpt_level_2 | Label for reporting level 2. |
rpt_level_3 | Label for reporting level 3. |
rpt_level_4 | Label for reporting level 4. |
rpt_level_5 | Label for reporting level 5. |
nms.srid | SRID for the NMS coordinate system. If not specified, then value of the MBS_GEO_SRID parameter from the CES_PARAMETERS database table is used. |
ll.srid | SRID for the coordinate system used in the extracted data. If not specified, then value of the MBS_LL_SRID parameter from the CES_PARAMETERS database table is used. |
