Dual-Environment Configuration
Oracle Utilities Network Management System has the option to use a dual-environment configuration to reduce downtime when installing patches.
Dual-environment configuration requires:
Two Unix users that are members of the same Unix group. Each user has their own installation of NMS executables.
Two WebLogic Managed Servers on the same WebLogic node. Each managed server must use a different port.
In this configuration, each environment is numbered 1 or 2 (based on the NMS_ENVIRONMENT environment variable). Only one of these environments can be active at a time.
While one environment is active, most of the steps for installing a patch can be performed on the other environment without interrupting users logged in to the active environment.
The following environment variables must have different values in the separate environments:
ISISPORT
ISISREMOTE
NMS_APPSERVER_PORT
NMS_ENVIRONMENT
NMS_MODEL_SOURCE
NMS_NS_PORT
ORACLE_READ_ONLY_USER
ORACLE_READ_WRITE_USER
The following parameters in the CES_PARAMETERS table must have different values in the separate environments:
WEB_corbaInitRef
WEB_mapDirectory
WEB_mapHttpdPort
WEB_oemHttpdPort
WEB_tempDirectory
The $NMS_DATA_FILES/model-sync-filter.cfg must exist and be a valid rsync filter configuration file. This is used by the nms-sync-model script (run by nms-setup and nms-post-setup) when syncing $OPERATIONS_MODELS from the other environment to the current environment. $NMS_BASE/templates/model-sync-filter.cfg.template is a template that can be used to create this file. Run the following command to copy the template:
cp $NMS_BASE/templates/model-sync-filter.cfg.template $NMS_CONFIG/sql/model-sync-filter.cfg
Edit if necessary to exclude any files or directories that should not be copied between environments, such as temporary files. In most cases, the template can be used as-is. Note that there should not be any blank lines in the file. Running nms-install-config will install the file from $NMS_CONFIG/sql to $NMS_DATA_FILES. More information about installing patches in this configuration can be found under Steps to Deploy a Patch Bundle in Dual-Environment Configuration in the Oracle Utilities Network Management System Installation Guide.
