High Level Messages
FLTService accepts the following High Level messages:
Action any.FLTService <command> <arguments>
Where:
Command
Arguments
Description
debug FLISR
<N>
Sets the debug level:
0 = off
1 = demand scan & timing info
2 = Trace
3 = Detailed Information regarding solution
4 = Full debug
flisr kva_tolerance
<N>
Sets the capacity tolerance to allow. Where <N> is the new tolerance in kVA
flisr base_flows
Outputs the base conductor flow information
flisr ties
Outputs the ties (open) point summary
flisr alarms
Forces a check for the Fault Location, Isolation, and Service Restoration disabled device alarms
flisr check
ON/OFF
Toggle Fault Location, Isolation, and Service Restoration check mode on/off
flisr reload
Reload measurement configuration
flisr dump
Write internal data structures into log
