Isis Directory Structure
The isis directory structure is provided for verification purposes only.
Directory
Contents
bin
Isis executables. The cmd command resides here as well. cmd provides a command line interface to isis that is useful for verifying connections and debugging problems.
lib
Isis runtime libraries
include
Contains isis include files used in compiling the software
run_isis
The run_isis directory should normally be under $NMS_HOME/etc/ and contains isis configuration files:
sites: Defines the node for this instance of isis.
isis.rc: provides startup information for isis
isis.prm: The isis parameter file. The location of the isis parameter file can also be overridden via the ISIS_PARAMETERS environment variable.
If not already created, the run_isis directory and its files will be created the first time you run isisboot.
