Isis Log Files
isis.[date].[time].log
The isis.[date].[time].log file keeps track of events while isis is initializing and is essentially the output file for the nms-isis start script. It is located in $NMS_LOG_DIR (or under $ISIS_LOG_DIR if it is set). The isis.[date].[time].log file contains clues if there is any difficulty in starting isis.
[Site No.].logdir
This is the directory where the Protos and Incarnation logs reside. The location of this directory is defined in the isis.rc file, and is typically found in $NMS_LOG_DIR/run.isis (or under $ISIS_LOG_DIR/run.isis, if $ISIS_LOG_DIR is defined).
The Protos Log
Protos is the isis protocol process. This process logs its messages to $NMS_LOG_DIR/run.isis/[Site No.].logdir.[port]/[Site No.]_protos.YYYYMMDD.HHMMSS.log or similar under the $ISIS_LOG_DIR directory if $ISIS_LOG_DIR is defined. Check here for runtime problems with isis. Each time isis is restarted, the previous protos log is moved to the old_log subdirectory. The retention period for logs in the old_log directory is driven by the $NMS_DAYS_TO_LOG environment variable or for 7 days, if the environment variable is not set. Each time isis is restarted it will delete logs older than the retention period.
The Incarn Log
There is a short file called $NMS_LOG_DIR/run.isis/[Site No.].logdir./[Site No.].incarn and it usually includes a single line containing the incarnation number for the particular site.
