Environment Configuration
The following must be configured for the training simulator to be used.
1. The "nms_training_simulator" product must be licensed in [project]_licensed_products.dat. See Verify Licensed Products File. Note that nms‑setup must be run after changing [project]_licensed_products.dat.
2. The WEB_envType parameter must be set to "training" in [project]_parameters.sql. This is what differentiates a training NMS environment from other types of NMS environments (such as production and test). This parameter should NOT be set to "training" in a production environment. See "Web Application Configuration" in the Oracle Utilities Network Management System Installation Guide.
3. The Trainer user type must be configured. This user type must have code_script='trainer' in the ENV_CODE table.
4. Services and the Managed server must be restarted after these changes have been made.
