Customer Model - Logical Data Model
This section provides an overview of the logical view of the Oracle Utilities Network Management System customer model. Where the MultiSpeak data model uses Customer, Service Location and Meter entities, the Oracle Utilities Network Management System model adds the notion of a Service Point to increase flexibility, and provide for improved performance of the physical implementation. Additionally, the Oracle Utilities Network Management System model extends beyond the basic MultiSpeak model in the following ways:
• Supports more than one meter per service location.
• MultiSpeak attributes not required for NMS purposes are not required, such as billing information (acRecvBal, acRecvCur, … ) and meterology information (kwh, multiplier, …)
• Provides model extensions to support important attributes not currently defined by MultiSpeak but necessary for NMS purposes.
• Supports customer-defined attributes for read-only purposes with no requirement for use in analysis.
This model, when joined with the Supply Node information in the Oracle Utilities Network Management System database (supply_nodes), results in the following E-R diagram:
Residential Model
In this extended model, it is recognized that the occurrence of multiple meters is reasonably common, where each meter may have different rate codes associated.
Although the occurrence of multiple transformers is much less frequent than multiple meters, there are also several possible configurations of meters and transformers, with different electrical arrangements. Often, multiple transformers will occur on (geographically) large sites (for example, factory, airport, shopping mall, and so forth), where it is appropriate and helpful (from the perspective of outage analysis) to have multiple service locations defined for the site which aid in readily locating the appropriate transformer.
The following pictures depict some simple examples of the usage of this customer model. The first example shows two service locations, each with a meter connected to a distribution transformer.
The second example is an account with a single location with two meters, which is described through the definition of a customer account, a service location and two meters. The service location is associated with a distribution transformer.
A third example would be a combination of the two previous examples, where a single customer account was responsible for the billing related to all of the above service locations. A more sophisticated example of residential metering is provided in the appendix.
Commercial and Industrial (C & I) Model
Many Commercial and Industrial situations are more complicated than residential metering. In these cases, a variety of configurations of meters, transformers and circuits must be addressed. The variations include:
• Primary metering, where the meter is placed on the high side of the transformer
• Internal buses, where two transformers can be used with two meters, feeding an internal bus
• Alternate transformers, where a meter can be switched to one of two transformers, each on a different circuit
• A single transformer feeding two meters, where different rates apply to each meter
The following diagram illustrates these examples.
Customer Model Database Schemas
The following section provides schema descriptions for the data and tables that are relevant to the Customer Model. It should be noted that the naming convention used internally is slightly different than the convention used in MultiSpeak or CIM exchange formats, due to the case-insensitive nature of Oracle RDBMS.
Customer Model Database Tables
The purpose of this section is to provide descriptions of the data and tables that support the implementation of the Oracle Utilities Network Management System customer model. These descriptions address only the data elements that are relevant to the customer model. The actual database tables may contain additional fields, but the other fields are not relevant to the customer model and are not described here. These additional fields can be project-specific.
Req Key Values
Meaning
Comment
N
Not required
Not needed for standard ces_customers table.
C
Configured in standard ces_customers table.
Not all columns referenced in the ces_customers table are required for a given implementation
- inclusion of some columns can be project-specific.
Y
Required
Used in standard ces_customers table – still may not be 100% required. Actual requirements are generally project specific.
Customers Table
The cu_customers table is used to manage customer accounts. While the primary key is cust_id, this typically may have the same value as account_number.
Req
Column Name
Data Type
Description
Y,C
cust_id
NUMBER NOT NULL,
Primary key – may be generated.
N
cust_account_number
VARCHAR2(30) NOT NULL
Customer account number.
N
cust_billing_account
VARCHAR2(13) NULL
Customer billing account number.
Y,C
cust_name
VARCHAR2(90) NULL
Name of the customer; concatenation of last, first and middle names, or business name.
N
cust_last_name
VARCHAR2(30) NULL
Last name.
N
cust_first_name
VARCHAR2(30) NULL
First name. Typically, this is only populated for residential customers.
N
cust_middle_name
VARCHAR2(30) NULL
Middle name or initial.
Y,C
cust_home_ac
NUMBER(3) NULL
Phone area code for the home phone.
Y,C
cust_home_phone
NUMBER(7) NULL
Phone number for the home phone.
N
cust_day_ac
NUMBER(3) NULL
Phone area code for the work phone.
N
cust_day_phone
NUMBER(7) NULL
Phone number for the work phone.
N
cust_day_phone_ex
NUMBER(7) NULL
Typically, day phone numbers are related to customers’ work phone numbers, which generally include extensions.
N
cust_bill_addr_1
VARCHAR2(50) NULL
Street address of the billing address. Note that billing address fields are usually populated only if different from the address held in the cu_service_point table.
N
cust_bill_addr_2
VARCHAR2(50) NULL
Second line, if necessary, of street address of the billing address.
N
cust_bill_addr_3
VARCHAR2(50) NULL
Third line, if necessary, of street address of the billing address.
N
cust_bill_addr_4
VARCHAR2(50) NULL
Fourth line, if necessary, of street address of the billing address.
N
cust_bill_city
VARCHAR2(30) NULL,
City of the billing address.
N
cust_bill_state
VARCHAR2(30) NULL
State of the billing address.
N
cust_bill_postcode_1
VARCHAR2(10) NULL
First 5 zip code numbers for US.
N
cust_bill_postcode_2
VARCHAR2(10) NULL
Second 4 zip code numbers for US.
C
cust_name_initials
VARCHAR2(3) NULL
The customer initials. Possibly used for certain soundex type searching if a customer wants to enable it - not often. Not necessary.
N
cust_comment
VARCHAR2(255)NULL
General field provided to support additional information about the customer, such as 30ft ladder, assult-case, crit-pmp-station, etc.
N
cust_user_def_1
VARCHAR2(255) NULL
These user-defined fields support the inclusion of other desired data not covered in the core fields. These fields can be extracted for project specific reporting.
N
cust_user_def_2
VARCHAR2(255) NULL
N
cust_user_def_3
VARCHAR2(255) NULL
N
cust_user_def_4
VARCHAR2(255) NULL
N
last_update_time
DATE
Time of last update for record. Generally, set internally when a record is updated - not via external CIS.
Y
birth
DATE
Time the record was activated
Y
death
DATE
Time the record was deactivated
Y
to_die
VARCHAR(1)
(Internal use.) Used to flag whether the record is being given a death time.
Service Locations Table
The purpose of the cu_service_locations table is to manage locations (premises) at which a customer is served. A customer account may have multiple service locations.
Req
Column Name
Data Type
Description
Y,C
serv_loc_id
NUMBER NOT NULL
N
serv_type
VARCHAR2(2) NULL
The type of service at this location. (electrical or gas). Only necessary for utilities that support multiple service types.
N
serv_status
VARCHAR2(50) NULL
Electrical service status of the service location. For example:
INA – Inactive
ACT – Active
PDI – Pending Disconnect
Can be used to coordinate business processes around how to handle customer disconnects (for example, update the day before). Each project needs to discuss these.
Y,C
serv_account_number
The service account number which will be used for call entry purposes, and the account number used in createIncident XML.
Y,C
serv_revenue_class
VARCHAR2(30) NULL
Revenue class for the service location.
N
serv_load_mgmt
NUMBER NULL
Binary - whether or not there is load management at this Service Location
Y,C
serv_concat_address
VARCHAR2(200) NULL
Concatenated address of the service address 1, 2, 3, and 4.
N
serv_special_needs
VARCHAR2(1) NULL
Identifies any special needs of the customer.
N
serv_priority
VARCHAR2(32) NULL
Mapped to ces_customers.priority. This defines the meaningful customer type value the utility uses internally. This value will be displayed on troubleInfo as well.
N
serv_addr_1
VARCHAR2(50) NULL
First line of street address of the service address.
N
serv_addr_2
VARCHAR2(50) NULL
Second line, if necessary, of street address of the service address.
N
serv_addr_3
VARCHAR2(50) NULL
Third line, if necessary, of street address of the service address.
N
serv_addr_4
VARCHAR2 (50) NULL
N
serv_city
VARCHAR2(25) NULL
City of the service location.
N
serv_state
VARCHAR2(25) NULL
State of the service location.
Y,C
serv_city_state
VARCHAR2(50) NULL
This field contains the data that will appear in the ces_customers.CITY_STATE field.
Y,C
serv_postcode_1
VARCHAR2(10) NULL
First 5 Zip Code numbers for US.
N
serv_postcode_2
VARCHAR2(10) NULL
Second 4 Zip Code numbers for US.
N
serv_user_geog_1
VARCHAR2(25) NULL
User geo codes typically used for political areas, such as counties, tax districts, etc.
N
serv_user_geog_2
VARCHAR2(25) NULL
Y,C
serv_town
VARCHAR2(3) NULL
The town or county for the customer.
Y,C
serv_str_block
VARCHAR2(20) NULL
Block number - used in searches.
N
serv_str_pfix
VARCHAR2(10) NULL
The 'R' in R 321 Rolling Rd (R rear, F front, A adjacent, etc.)
Y,C
serv_str_struc
VARCHAR2(20) NULL
Structure relates to apartments, units, piers, docks, warehouse, slip, etc.
N
serv_str_name
VARCHAR2(30) NULL
Name of the street (Main Street).
N
serv_str_cdl_dir
VARCHAR2(10) NULL
Cardinal direction (N, S, E, W).
N
serv_str_sfix
VARCHAR2(10) NULL
ST, PKY, PLC, DR, RD, AVE, etc.
Y,C
serv_lot
VARCHAR2(10) NULL
Lot number – used in searches.
Y,C
serv_apt
VARCHAR2(8) NULL
Apartment number.
N
serv_elec_addr
VARCHAR2(50) NULL
Elec address used in searches.
N
serv_sic
VARCHAR2(8) NULL
Standard Industrial Code.
N
serv_comment
VARCHAR2(255) NULL
General comment about the service location.
Y,C
serv_cumulative_priority
NUMBER NULL
Summation of priority codes for this location.
Y,C
serv_life_support
NUMBER NULL
Indicates if this is a life-support customer.
Y,C
serv_a_priority
NUMBER NULL
A customer defined flag, 0 or 1
Y,C
serv_b_priority
NUMBER NULL
B customer defined flag, 0 or 1
Y,C
serv_c_priority
NUMBER NULL
C customer defined flag, 0 or 1 – often emergency customers.
Y,C
serv_d_priority
NUMBER NULL
D customer defined flag, 0 or 1 – often medical customers.
Y,C
serv_e_priority
NUMBER NULL
E customer defined flag, 0 or 1 – often entertainment customers.
Y,C
serv_f_priority
NUMBER NULL
F customer defined flag, 0 or 1 – often fire customers.
Y,C
serv_g_priority
NUMBER NULL
G customer defined flag, 0 or 1 – often government customers.
Y,C
serv_h_priority
NUMBER NULL
H customer defined flag, 0 or 1 – often hospital customers.
Y,C
serv_i_priority
NUMBER NULL
I customer defined flag, 0 or 1
Y,C
serv_j_priority
NUMBER NULL
J customer defined flag, 0 or 1
Y,C
serv_k_priority
NUMBER NULL
K customer defined flag, 0 or 1 – often keycustomers.
Y,C
serv_l_priority
NUMBER NULL
L customer defined flag, 0 or 1 – often life support customers.
Y,C
serv_m_priority
NUMBER NULL
M customer defined flag, 0 or 1 – often manufacturing customers.
Y,C
serv_n_priority
NUMBER NULL
N customer defined flag, 0 or 1 – often nursing home customers.
Y,C
serv_o_priority
NUMBER NULL
O customer defined flag, 0 or 1
Y,C
serv_p_priority
NUMBER NULL
P customer defined flag, 0 or 1 – often police customers.
Y,C
serv_q_priority
NUMBER NULL
Q customer defined flag, 0 or 1
Y,C
serv_r_priority
NUMBER NULL
R customer defined flag, 0 or 1
Y,C
serv_s_priority
NUMBER NULL
S customer defined flag, 0 or 1 – often sensitive customers.
Y,C
serv_t_priority
NUMBER NULL
T customer defined flag, 0 or 1 – often transportation customers.
Y,C
serv_u_priority
NUMBER NULL
U customer defined flag, 0 or 1
Y,C
serv_v_priority
NUMBER NULL
V customer defined flag, 0 or 1
Y,C
serv_w_priority
NUMBER NULL
W customer defined flag, 0 or 1
Y,C
serv_x_priority
NUMBER NULL
X customer defined flag, 0 or 1
Y,C
serv_y_priority
NUMBER NULL
Y customer defined flag, 0 or 1
Y,C
serv_z_priority
NUMBER NULL
Z customer defined flag, 0 or 1 – often 911 customers.
Y,C
serv_map_loc_x
NUMBER NULL
GPS lat/long or other mapping coordinates.
Y,C
serv_map_loc_y
NUMBER NULL
N
serv_user_def_1
VARCHAR2(255) NULL
These user-defined fields support other desired data not covered in the core fields. These fields can be extracted for project-specific reporting purposes.
N
serv_user_def_2
VARCHAR2(255) NULL
N
serv_user_def_3
VARCHAR2(255) NULL
N
serv_user_def_4
VARCHAR2(255) NULL
N
last_update_time
DATE
Y
birth
DATE
Y
death
DATE
Y
to_die
VARCHAR(1)
Meters Table
The cu_meters table describes meters that might exist at a service location. The use of meters is optional (but increasingly common) within Oracle Utilities Network Management System. Meter information is required for a project which intends to utilize integration with an Automated Meter Reading Infrastructure.
The cu_service_points table tracks the relationship between a meter (cu_meters) and a customer account (cu_customers) and service location (cu_service_locations).
Req
Column Name
Data Type
Description
Y,C
meter_id
NUMBER NOT NULL
Y,C
meter_no
VARCHAR2(20) NOT NULL
Meter number.
N
meter_serial_number
VARCHAR2(20) NULL
Serial number on the meter.
N
meter_type
VARCHAR2(20) NULL
Type of meter (gas, electric, water, etc.).
N
meter_manufacturer
VARCHAR2(20) NULL
Manufacturer of the meter.
N
meter_phases
VARCHAR2(1) NULL
Phase(s) connected to the meter (IE 1, 2, or 3).
N
meter_rate_code
VARCHAR2(65) NULL
Rate code for the meter.
N
meter_user_def_1
VARCHAR2(255) NULL
These user-defined fields support other desired data not covered in the core fields.These fields can be extracted for project-specific reporting purposes.
N
meter_user_def_2
VARCHAR2(255) NULL
N
meter_user_def_3
VARCHAR2(255) NULL
N
meter_user_def_4
VARCHAR2(255) NULL
N
last_update_time
DATE
Y
birth
DATE
Y
death
DATE
Y
to_die
VARCHAR(1)
N
bellwether
VARCHAR2(1) NULL
Bellwether meter flag (Y/N).
N
meter_amr_enabled
VARCHAR2(1) NULL
AMI-enabled meter flag (Y/N).
N
voltage_threshold
NUMBER NULL
Low voltage threshold.
N
nominal_voltage
NUMBER NULL
Meter nominal voltage.
Account Type Table
The purpose of the cu_account_type table is to contain a configuration of the valid Account Types that can be specified for a Service Point record. The initial loading of customer data populates this table. There is often only one row in this table (for electrical service).
cu_account_type
Column Name
Data Type
Description
acctyp_account_type
VARCHAR2(10) NOT NULL
Electric, Gas, Propane, Appliance Repair, etc.
acctyp_user_def_1
VARCHAR2(255) NULL
acctyp_user_def_2
VARCHAR2(255) NULL
acctyp_user_def_3
VARCHAR2(255) NULL
acctyp_user_def_4
VARCHAR2(255) NULL
Service Points Table
The purpose of the cu_service_points table is to manage the linkages between the cu_customers, cu_service_locations, cu_meters, cu_account_type and supply_nodes tables.
Key indexes are placed on this table for performance. History can be tracked, by setting active_fl to 'N' to identify that a record is now historical. No timestamp is used to track when a service point went out of service and the cu_service_points table is not intended nor recommended as a long term repository for service point history.
Req
Column Name
Data Type
Description
Y,C
serv_point_id
VARCHAR2(64) NOT NULL
Primary key. If the CIS cannot provide a unique value, use a generated key (for example, by combining cust_id, serv_loc_id and meter_id columns). This is used for CIS-to-NMS integration. For Customer Care & Billing (CC&B) integration in Oracle Utilities Network Management System 1.10, this is the CC&B Service Point Id. (See below for related info on ces_customers).
Y,C
cust_id
NUMBER NOT NULL
Foreign key ref to the cu_customers table.
Y,C
serv_loc_id
NUMBER NOT NULL
Foreign key ref to the cu_service_locations table.
Y,C
meter_id
NUMBER NOT NULL
Foreign key ref to the cu_meters table.
Y,C
device_id
VARCHAR2(25) NOT NULL
Foreign key ref to the supply_nodes table. This field is critical and necessary, as it ties Oracle Utilities Network Management System to the CIS.
N
feeder_id
VARCHAR2(10) NULL
Foreign key ref to the supply nodes table. Note this field is non-critical and generally not necessary.
Y,C
active_fl
VARCHAR2(1) NOT NULL
Identifies currently active records. Generally, this is always ‘Y’ as there is little provision or need for inactive records in the system. Inactive records are generally removed from this table.
N
create_dttm
DATE NOT NULL,
Timestamp for the record's creation.
Y,C
account_type
Foreign key to the cu_account_type table.
N
last_update_time
DATE
Time of last update.
Y
birth
DATE
Y
death
DATE
Y
to_die
VARCHAR(1)
DERs Table
The purpose of the cu_ders table is to manage the distributed energy resources (DERs) that may be connected to a meter. The use of this table is optional depending on whether distributed energy resources are present on the associated distribution network. The information stored within this table can be used within the Trouble Info Customer List to display relevant information related to DERs associated to a particular customer. If distributed energy resources do not exist within the GIS data, this table can be used by the model preprocessing to artificially inject these devices into the NMS model. The preprocessing can determine the service transformer associated to the DER and then add a DER of the indicated technology type to the NMS model. .
Req
Column Name
Data Type
Description
Y,C
der_id
NUMBER NOT NULL
Y,C
der_name
VARCHAR2(80) NOT NULL
Name of the DER.
Y,C
meter_id
NUMBER NOT NULL
The corresponding ID of the connected meter.
N
der_type
VARCHAR2(30) NULL
Technology type for the DER (PV, wind, etc.).
N
der_phases
VARCHAR2(1) NULL
DER phasing.
N
rated_size
VARCHAR2(30) NULL
The size of the DER in kVA.
N
nominal_voltage
NUMBER NULL
The nominal voltage value of the DER.
N
der_user_def_1
VARCHAR2(255) NULL
N
der_user_def_2
VARCHAR2(255) NULL
N
der_user_def_3
VARCHAR2(255) NULL
N
der_user_def_4
VARCHAR2(255) NULL
N
last_update_time
DATE
Y
birth
DATE
Y
death
DATE
Y
to_die
VARCHAR(1)
Linkages to Other Tables
The customer model has linkages to other tables in the Oracle Utilities Network Management System model. The primary linkage between utility customers and the Oracle Utilities Network Management System electrical network model is the device_id column. The definitive table linkage is between supply_nodes.device_id and cu_service_points.device_id. From the perspective of the cu_service_points table, the device_id field is used to uniquely identify the electrical network model element (supply node) which supplies power to a service point (customer).
In general, an Oracle Utilities Network Management System supply node is any place on the model where a utility customer can be connected to receive electrical power. For customers that wish to model secondary network, this supply point can be associated with a single customer/meter. For customers that are only interested in modeling primary distribution circuits, the supply node is often associated with a secondary transformer.
The Oracle Utilities Network Management System electrical data model is implemented under the assumption that the source for the electrical network model data (generally a Geographic Information System) and the source for the utility customer data (generally a Customer Information System) understand and maintain this customer-to-supply-node relationship. The accuracy of this linkage is critical for reliable trouble call handling and outage reporting. Without this linkage, customer trouble calls enter the system as fuzzy calls and outage reports have diminished accuracy.
