Client Development Installation Overview
Follow these steps to install, build and deploy the Oracle Network Management System Grid Edge DERMS:
1. Use the table in the Hardware Requirements section to identify the supported build environment platforms.
2. Review and prepare for the download and installation of required Oracle and third-party software as described in the Prerequisite Software section.
3. Install the third-party software.
4. Because the Oracle Network Management System Grid Edge DERMS application uses the Operations Mobile Application framework, you will need to use the following Operations Mobile Application files located in $NMS_BASE/sdk/.
• Unzip OMA2.zip file to your build environment system.
• Unzip OMA2.3rdparty.zip file to your build environment system.
5. Install the Node.JS from https://nodejs.org. You will need version 14.17.3 or higher.
6. Build the Oracle Network Management Systems Grid Edge DERMS App.
7. Run the built client using the browser to test your built application.
