Functional Area | Description |
Outage Management System Base | The Oracle Utilities Network Management System (NMS) operations model, and tools to support and administrate the model and integration to leading GIS vendors. Core functionality to manage outages, including tracking of outage durations at the customer level, outage causes, and actions taken. Includes: Web Workspace, Web Trouble, Model Management, Topology Validation, Configuration Assistant, Generic IVR Adapter, GIS Adapters (Esri, Intergraph, GE Smallworld) |
OMS Option: Outage Management Switching and Schematics | Functionality that allows operators to record switching actions electronically via interaction with a map view of the covered service area and operations model. Also the ability to generate schematic diagrams of the major network model elements. Includes: Web Switching Management, Schematics (schematica) |
OMS Option: Outage Management Adapters | Modules for integrating Oracle Utilities Outage Management System to foreign systems such as CIS, IVR, AMI, AVL, and Mobile systems. Includes: Generic IBM MQ Mobile Adapter, MultiSpeak adapter flows for AMI and AVL integration, and SOAP Web Services |
OMS Option: Outage Management Call Center | Tools used to enter calls into the system, easily query status of specific customers, and track the progress of restoration callbacks. Includes: Web Call Entry, Web Callbacks |
OMS Option: Outage Management Storm Management | Functionality used to estimate when assessment and restoration will be complete for various types of outages, broken out by section of the distribution network. Ability to forecast the impact of bringing on additional resources, or determining the resource need to meet target objectives. Includes: Storm Management |
OMS Option: Outage Management Paging | Functionality used to provide automatic internal notifications from the Oracle Utilities Outage Management System to identify specific customers affected, major outages, beginning and ending of storm events, and status of planned outages. Includes: Service Alert |
OMS Option: Network Management Flex OMS Client | A browser-based version of NMS providing core OMS capabilities to take authority, see lists of events and crews within subscribed area, be able to view and update crew statuses and event details, and see a distribution network interactive map with functionality similar to the Operations Mobile Application. Note: Flex Operations is not supported on tablets or smartphones. Includes: Flex Operations core OMS functions |
Distribution Management System Base | The Oracle Utilities Network Management System (NMS) operations model, and tools to support and administrate the model and integration to leading GIS vendors. Functionality that allows operators to record switching actions electronically via interaction with a map view of the covered service area and operations model. Includes: Web Workspace, Web Switching Management, Model Management, Topology Validation, Configuration Assistant, GIS Adapters (Esri, Intergraph, GE Smallworld), Schematics (schematica) |
DMS Option: Distribution Management Power Flow | Functionality that provides an integrated three phase unbalanced power flow solution built into the system operator's normal business processes and work flows to provide enhanced decision support. Includes: Power Flow, Weather Data Adapter, DERMS Adapter, Profile Adapter |
DMS Option: Distribution Management Advanced Feeder Management | Functionality that allows operators to query the system for recommendations of specific switching situations, including load shed events. The system can present a set of switching actions to address a set objective which the operator can review, modify, and utilize. Also the ability to see hourly peak forecasts for the next 24 hours and daily peak forecast for the remainder of the week to provide advance warning of potential load issues, allowing proactive responses. Includes: Suggested Switching, Load Shed & Restoration, Feeder Load Management |
DMS Option: Distribution Management Fault Location Isolation and Service Restoration | Functionality that, based on SCADA triggers such as lockouts and fault indications/location, determine the specific protective device which has cleared a sustained fault, identifies the de-energized sections, and determines the available alternate supplies for re-energization. Includes: Fault Location, Isolation, and Service Restoration |
DMS Option: Distribution Management Volt/VAr Optimization | Functionality that helps operators to recognize and be able to affect voltage on the network, utilizing the power of the system to prepare and present recommendations to the operator for action. Includes: Network Optimization |
DMS Option: Distribution Management Fault Location Analysis | Functionality that determines the distance downstream of fault measurements where a fault is estimated to have occurred. All potential fault locations are displayed in graphical and tabular formats and the operator can incrementally reject or confirm fault locations as crews provide feedback on fault dispatches. Includes: Fault Location Analysis |
NMS Option: SCADA Interface | Functionality that supports bringing in SCADA data via a variety of standards-based adapter options, displaying SCADA Summary data and SCADA Alarms, and leveraging the data in support of DMS applications. Outbound SCADA controls are also supported. Includes: SCADA Extensions, SCADA Measurements adapter (scadapop), Generic SCADA Adapter, ICCP Adapter, MultiSpeak SCADA Adapter, OSI SCADA Adapter, SCADA Calculation Engine |
NMS Option: Flex SCADA | Full Distribution SCADA (D-SCADA) application functionality. Requires an additional Live Energy Connect (LEC) license for industrial protocol Front End Processor (FEP) and communications support. Includes: Display Editors, Device Commissioning, Measurement/State Validation, Limits Processing, Calculated Points, Alarms Processing, Sequence of Events, Trending, Logging |
NMS Option: Training Simulator | Functionality that allows a trainer to record scenarios including customer calls, AMI last gasps, and simulated device operations in support of training. Each scenario can be played back for a trainee, paused, modified, and monitored by the trainer. Includes: NMS Training Simulator |
NMS Option: Operations Mobile Application | Application for Android, iOS, and Windows devices that allows field personnel to be quickly registered, assigned work, update status, report blocked roads, enter damage assessment details, receive and respond to switching steps, and update basic NMS event information such as ERT, notes, and so forth. REST API also can be used to integrate a 3rd-party mobile solution to NMS. Includes: Operations Mobile Application template app, REST API |
NMS Option: Distribution Management Operational DERMS | Functionality that enables dispatch of DER through optimized plans (Network Optimization/Suggested Switching/FLISR). Enables Active Network Management Switching. Enables Network Capacity Allocation which manages Distributed Energy Resource markets. Includes: Active Network Management |
NMS Option: Network Management Flex NMS Client | An add-on to the Flex OMS Client that provides additional browser-based functionality such as switching management and some other NMS functions beyond the core OMS functions of the Flex OMS Client. Includes: Flex Operations additional NMS functions. Requires Network Management Flex OMS Client. |
NMS Option: Distribution Management Grid Edge DERMS | Functionality that allows users to control the dispatch of aggregator-managed DER at the Behind The Meter level through strategies and events. Grid Edge DERMS is an integrated part of Oracle’s DERMS solution that requires Oracle Utilities Network Management System, Oracle Utilities Live Energy Connect (LEC), Oracle Utilities Analytical Insights (OUAI), Oracle Integration Cloud (OIC), and Oracle Utilities Digital Asset Management (DAM). |
