Mobile Gateway Architecture
The Mobile Gateway can be deployed on premise or in the cloud:
![Mobile Gateway Architecture showing HTTPS requests through RESTful API calls. Mobile Gateway Architecture showing HTTPS requests through RESTful API calls.](../NMS_OMA_INSTALL-DEPLOY_26010/images/OMA_OnPremise.png)
This architecture addresses many security concerns limiting the access from the Internet to the corporate network.
How Operations Mobile App devices connect to the NMS instance:
1. The Operations Mobile App client device connects to a dedicated WebLogic Managed Server, called the NMS WebLogic Mobile Gateway (WLMG), using HTTPS making RESTful Web Service requests.
2. The WLMG places Operations Mobile App client requests on the JMS in-memory “requests” queue.
3. The primary NMS WebLogic Managed Server (WLMS) connects to the JMS “requests” queue on the WLMG as a JMS client using the WebLogic t3s protocol and pulls requests off the “requests” queue and processes the requests via the normal channel from WLMS to NMS Services.
4. The WLMS then places responses to valid Operations Mobile App client requests on the parallel JMS in-memory “responses” queue – in a similar fashion to how the “requests” queue is handled.
5. The WLMG replays to the HTTPS RESTful Web Services request with the WLMS responses
6. The Operations Mobile App client device takes the HTTPS response and processes it on the device.
Notes:
• It is recommended to have an Oracle HTTP server or other reverse proxy server to further isolate OMA from the internet.
• There should be a firewall rule that allows only access to the https port from the internet (all other ports should be blocked).
