The Cancel button closes the Remove Measurements window without changing the graph.Choosing the Analog Measurements to Display in the Viewer
An Administration user type may choose which measurement types (for example, water level, pressure, etc.) to display in the Viewer for a particular asset.
Note: Users must have Measurements selected in the Viewer Hide/Display dialog box to see any measurements.
To add or remove a measurement type for an asset, first load the Viewer map containing the device, then select the SCADA summary row for the asset measurement type, right-click, and choose one of the following options:
• Show Measurement in Viewer: Shows the selected measurement in the Viewer.
