High Contrast
If you require a high contrast display, select the High Contrast or Light color theme. See the
Understanding the User Interface Settings Menu for information.
You can disable high contrast forced colors in the Google Chrome browser while using Flex Operations as follows.
1. In Chrome, type "chrome://flags" in the search bar. This will take you to the "Experiments" page.
2. On the experiments page, use the search bar and search for "Forced Colors".
3. Choose the "Disabled" option from the Forced Colors Drop-down.
4. Relaunch chrome.
