Understanding Printing in Oracle Utilities Network Management System
Printing is an option in many windows. The Print Preview dialog box appears whenever one of the printing options is selected in Web Workspace or Web Trouble. The following table describes the buttons on the Print Preview dialog box.
Button
Description
Used to preview the previous page in a multi-page output.
Used to preview the next page in a multi-page output.
Used to zoom out on the contents of the preview.
Used to zoom in on the contents of the preview.
Used to scale out the font used for the print output.
Used to scale in the font used for the print output.
Toggles the page orientation of the output between portrait and landscape.
Brings up the Page Setup dialog box, which allows you to select paper size and source, set page orientation, set margins, and select the printer.
Reverts the preview window back to its default settings.
Sends the print output to your selected printer, and then closes the Print Preview dialog box.
Close
Closes the Print Preview dialog box without printing any output.
Setting Print Margins
The Print Preview dialog box also allows you to set the margins of the output interactively. Follow these steps:
1. Position your cursor over the preview output until you see a red outline and your cursor becomes a double-headed arrow.
2. While the cursor is a double-headed arrow, click and hold your left mouse button and drag the red line to the desired location.
