Bulk Crew Loading and Deleting (Administrative Users)
Administrative Users may perform a bulk import or deletion of crews and crew components (members and vehicles) using the nms‑load‑crews program. The program, which is run from a terminal, requires separate CSV files for crews, crew members, and vehicles.
nms‑load‑crews -crews filename
-members filename
-vehicles filename
[-add|-delete]
[-force]
[-status inactive|off-shift|on-shift]
[] optional parameter
Options
crews: Required. The crew file to import.
members: Required. The members file to import.
vehicles: Required. The vehicles file to import.
add|delete: Whether to add or delete the crews, members, and vehicles. The default is add, which is assumed if omitted.
status: Used with the -add option. Whether to add new crews as inactive, off-shift, or on-shift. Default: off-shift.
force: Used with the -delete option. Whether to force the deletion of active crews. Default: false.
Example
nms‑load‑crews -crews crews.csv -members members.csv -vehicles vehicles.csv
Crew CSV Columns
The columns in the Crew CSV file matches the CREWS database table column names:
CREW_KEY: numerical key for the crew
CREW_TYPE: CREW_TYPES.CREW_TYPE value
TEMP_FLAG: temporary crew Y/N flag
ZONE_NAME: CONTROL_ZONES.NAME value
ZONE_CLS: CONTROL_ZONES.NCG_CLASS value
ZONE_IDX: CONTROL_ZONES.NCG_ID value
CREW_SIZE: the crew size
CONTACT: the contact name
CREW_NAME: the crew name
MOBILE_NUM: the mobile number
MOBILE_CARRIER: the mobile carrier
ALTERNATE_NUM: the alternate contact number
ALTERNATE_NUM_TYPE: the alternate contact number type
PAGER_NUM: the pager number
MDT_CREW: MDT crew Y/N flag
EXTERNAL_KEY: external ID of the crew
OUT_OF_RANGE: out of range Y/N flag
MOBILE_FLAG: Y, N, or O (mobile overridden for NMS)
MEMBERS: colon-separated list of MEMBER_EMP_NUMB
VEHICLES: colon-separated list of VEHICLE_NUMB
Crew Member CSV Columns
The columns in the Crew Members CSV file matches the CREW_MEMBERS database table column names:
MEMBER_NAME: member name
MEMBER_CLASS: CREW_MEMBER_CLASSES.MEMBER_CLASS
MEMBER_EMP_NUMB: employee ID
Crew Vehicles CSV Columns
The columns in the Crew Vehicles CSV file matches the CREW_VEHICLES database table column names:
VEHICLE_TYPE: CREW_VEHICLE_TYPES.VEHICLE_TYPE
VEHICLE_NUMB: vehicle ID
Using Bulk Add/Delete Scripts
For convenience, two scripts (nms‑add‑crews and nms‑delete‑crews) are available to run the bulk crew changes. Pass arguments to these scripts as stated above or create your own project version that uses a consistent set of options that follow your project's business practices.
Examples
nms‑add‑crews -crews crews.csv -members members.csv -vehicles vehicles.csv
nms‑delete‑crews -crews crews.csv -members members.csv -vehicles vehicles.csv
nms‑delete‑crews -crews crews.csv -members members.csv -vehicles vehicles.csv -force
