Storm Management View Only Environment
The Storm Management View Only environment is available for users who do not have a need to manipulate the various parameters on the Storm Management window, but rather need to monitor and analyze the information that is presented. To access the Storm Management View Only environment, login with View Only user type.
View Only Environment User Interface
View Only Menus
There are three menus on the View Only Storm Management menu bar: System, Storm, and Help.
Menu
The options in the System menu are available in both storm and non-storm modes. The following table describes the System Menu options and associated toolbar icons.
Storm Menu
The option in the Storm menu is only enabled when Storm Management is in storm mode for the selected control zone.
The following table describes the Storm Menu options.
View Only Help Menu
The Help menu options are Storm Management Help, which opens the online help content for Storm Management, and About Storm Management, which displays information regarding the version of the application and the Web Gateway.
View Only Toolbar
The Storm Management toolbar provides a shortcut to many of the options available from the Storm Management menus.
The View Only Storm Management toolbar displays the following buttons.
• The Retrieve Update button refreshes the window with the most recent information from the system. In most cases, the window refreshes itself on a periodic basis. But, if there are unsaved changes in the Storm Management window at the time the automatic refresh is due to occur, the window will not refresh. Instead, an alert appears in the status bar indicating that an update is available, and the Retrieve Update option must be invoked in order to refresh the window with the new update. This allows you to continue on with your changes and save them first before refreshing.
• The Calculate Crews button opens the Calculate Crews dialog box, which is used to determine the approximate number of crews needed to complete assessment and repair by a specified date. This option is only available in storm mode.
