Enabling and Disabling FLISR Devices from the Control Tool
You can enable or disable devices for FLISR actions by clicking the Enable FLISR or Disable FLISR buttons from the Control Tool. These buttons are displayed for all FLISR devices.
When a FLISR device is disabled, a condition flag is shown on the Viewer adjacent to the device.
Note: Disabling a Circuit Breaker or a Recloser will implicitly disable all downstream FLISR actions. Disabling a non-reclosing device (that is, a simple sectionalizer) will only disable the individual device.
