Using the Miscellaneous Log
The Miscellaneous Log records actions taken outside of a switching sheet. When you perform an action through the Operate Device dialog box (from the Map's Selection Panel), the Record Into Sheet field will show whether you are recording to the Miscellaneous Log or to a switching sheet.
To view the location of the device from the selected record, click the
Focus button (
) or select
View on Map... from
Actions menu. The Map will open (if not already open) and focus on the device from the selected record row.
See
Using the Miscellaneous Log for information on the Miscellaneous Log.
