Command Line Option | What it does |
-cert_file <full path to certificate> | The private certificate used for incoming device/screen navigation messages from the SCADA system. This is the server's private key concatenated with its certificate, as used by GSOAP. |
-client_cert | Whether to require public certificates for incoming screen navigation messages from the SCADA system. This is the client key concatenated with the certificate. |
-controls <script name> | Tells RTAdapter to call this project/SCADA specific script when NMS outbound control requests (digital open/close or analog set point control) are made. This script is typically customized to trigger a SCADA specific action on the external system. Note: this option MUST be set for RTAdapter to do any processing of outbound control requests. |
-debug | Enable debugging. Other common facility specific debug options are also possible. Common options include: -debug RT_NFY 1 # debug for notify messages -debug RT_CALC 1 # debug for calculated points -debug RT_CTRL 1 # debug for control msg processing -debug RT_PROC 1 # debug for outage processing -debug RT_WATCH 1 # debug to track high-level activity -debug RT_COND 1 # debug for condition processing -debug RT_STALE 1 # debug for stale processing |
-delimiter <char> | Allows a project to override the default input delimiter character (|) with the specified character.Used for file based input and, potentially, for setting multiple external quality code strings, which must be mapped back to integers internally, via RDBMS‑based input. |
-dir <directory> | For file based input this is the directory containing scada data export scan files. For RDBMS based input this must be set to 'RDBMS'. (Required) |
-idle <cycles> | Number of processing cycles to wait without processing any data before sending an alarm. |
-interval <interval> | Seconds between processing (polling) cycles. (Required) |
-lock | Use file locking to prevent file overwrite during file read (if scan file names are not unique). File based input only. |
-no_analogs | Do not scan the scada_analog_in table or process analogs. |
-noStaleProcessing | Do not generate stale quality codes. This is useful primarily in testing and training environments when you have two instances of the adapter configured to use the same SCADA points, and you do not want them to both generate conflicting stale quality flags. |
-offline | For testing purposes - when a control request is received - simulate the external SCADA system and operate the device. |
-offlineDelay <seconds> | Seconds between receiving a CONTROL request (in offline mode) and responding. Used to help simulate an actual SCADA system. |
-operate | Operate (change status of) model devices, otherwise generates pseudo alarms only. |
-process_name <name> | Network Management System message bus process name for this process. If the first parameter after the keyword program in the first column of the system.dat file is something other than the second parameter, then you must set the ‑process_name option to the same string as the first parameter. This is only necessary if you need to run more than one instance of RTAdapter or you want RTAdapter to be known as some other name within the Network Management System messaging bus. Network Management Process message bus process names must be unique. |
-retain | For RDBMS input only. Retain data in the scada_digital_in, scada_condition_in, and scada_response_in tables after data is processed. Generally for validation/debug - not general purpose production use or long term logging. |
-scada <scada> | External SCADA name. (Required). Must match an active SCADA entry in the scada_ids table (scada_ids.scada_name). |
-watch <level> | Show data being processed, minimal info. <level> is an integer that maps to the RT_WATCH debug facility. |
-config <scada> | When used to support the NMS MultiSpeak adapter we want RTAdapter and MultiSpeak to process the "same" measures from a scada_id perspective. This option allows specification of an alternate scada (which must still be an active scada_name entry in the scada_ids table). Using this option allows run-time configuration for the RTAdapter and MultiSpeak adapters in the scada_synonyms, scada_states and scada_links tables to NOT overlap. |
-dbname <dbname> | Name of DBService process used by RTAdapter. Default is DBService. |
-noStaleProcessing | Do NOT generate stale quality code for measurements. |
Script | Description |
rti‑notify‑start | Notifies the SCADA system that the Generic SCADA Adapter has restarted. Call from RTAdapter on restart. |
rti‑operate | Example script for use with the RTAdapter controls option (for example, ‑controls rti‑operate). This script can either forward to SCADA or simulate a SCADA positive response when device control requests are sent from NMS. The rti-operate-curl script is a simplified version of the rti-operate script. It is an example of how to use curl to call an external system to propagate NMS initiated device operation requests to an external system. Either script (or a project alternative) can be specified via the "-controls <script>" command line option. |
rti-pseudo | pseudo measures are not actually telemetered from the field but may be maintained manually within a SCADA system. NMS identifies a pseudo measurement as having the corresponding scada_measurements_st.ttl=2 (see Understanding TTL). If a pseudo measure is changed by an NMS operator this script will be called to support optional propagation of the update to the external SCADA system. |
scada‑reload | Notifies the SCADA system that the set of measurements has changed due to an NMS model build. |
rti‑operate‑curl | Another example script for use with the RTAdapter controls option. Sends the control request to the SCADA system as a RESTful web-service request via curl. |
rti-condition | If RTAdapter is configured to propagate conditions (via the RT_CONDITIONS_OUT srs_rule) and a new/updated NMS condition inherits from the scada_out_tag abstract NMS class, this script will be called to propagate the condition. |
rti-emulator | Another example -controls <script> that can be used in conjunction with EMService to help simulate an external SCADA system. |
Parameter | Description |
SCADA_URL | Used to identify the external SCADA. RTAdapter will send navigation and SCADA controls to the SCADA system via this URL. The SCADA_URL should be the root URL. The scripts will add instruct, reload, navigate, etc. to the URL as needed. This is a site‑specific parameter. Legacy support only; not typically used. |
SCADA_CERT | The certificate to connect to the SCADA system. This is the client piece of a certificate generated by the SCADA system. This is a site‑specific parameter. Legacy support only; not typically used. |
